03-09-2019, 02:02 PM | #1 |
Help, Won't Start.
Recently bought a 1977 c10 fitted with a 350 SBC that needed a bit of TLC, It was not running very well when I got it
I started of by taking one of the heads off to sort a snapped exhaust manifold bolt and leaking exhaust manifold gaskets. I rebuilt it with new head gasket, New inlet manifold gaskets and exhaust gaskets. I also fitted new spark plugs, ignition wires, distributer cap, rotor arm and carburettor. Im sure I have the distributor set right, TDC set to no 1 cylinder, right firing order and I have reset the valve gaps. I have a spark and I have fuel getting to the carb but it will not fire up. Im at a total loss as to why it will not start, any ideas ??? please help |
03-09-2019, 02:14 PM | #2 |
Re: Help, Won't Start.
You could be off 180 degrees on the dizzy or you have the valves set wrong.
03-09-2019, 11:52 PM | #3 |
I second what geezer said. Make sure you have the #1 piston TDC on the compression stroke (not the exhaust stroke)before setting the distributor in. Also make sure the rotor is pointing at the #1 terminal on the cap after it is set in.
03-10-2019, 02:19 AM | #4 |
Anytime I'm sure of something and the problem isn't solved, I find the thing I'm so sure isn't the problem, is.
03-10-2019, 02:47 PM | #5 |
All sorted, Valves to tight, Thanks
03-12-2019, 03:27 PM | #6 |
Glad you got it sorted out. Cool truck, too!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
