07-27-2017, 10:31 PM | #1 |
Fuel pressure reg
I am installing 6.0 returnless fuel system in my suburban. Do I need to install a regulator downstream of the pump. Can it be done without a regulator.
Pulatoy |
07-27-2017, 10:41 PM | #2 |
Re: Fuel pressure reg
you will need a inline regulator between the pump and fuel rails..commonly used is the wix vette filter/reg..are you going to use a inline or intank pump?...I used walbro 255 inlime pump on mine..the regulator will need to return back into the tank
