Old 03-02-2019, 07:02 PM   #1
Fuji
Wheel and Tire selection for a 1970 Step Side
We are looking at a Hotchkis TVS suspension system for our project but are having trouble determining the potential tire and wheel size after a 4" front and 6" rear lower. Has anyone dealt with this suspension?
Fuji is offline   Reply With Quote
Old 03-03-2019, 08:30 AM   #2
Re: Wheel and Tire selection for a 1970 Step Side
For information on tire fitment you can post your question in the wheel & tire board, too.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling)
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 03-06-2019, 09:36 AM   #3
68Stepbed
68Stepbed's Avatar
Any particular reason to run the Hotchkis vs. other options? The reason I ask, is because the Hotchkis setup hasn't really been the go-to for truck handling and there's better options.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-06-2019, 09:38 AM   #4
68Stepbed
68Stepbed's Avatar
We have a wheel & tire section?
Matt
Old 03-06-2019, 10:12 AM   #5
SCOTI
SCOTI's Avatar
x2?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 03-06-2019, 10:20 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-06-2019, 10:33 AM   #7
oldman3
oldman3's Avatar
I've never seen it, but would be good...Jim
oldman3 is offline   Reply With Quote
Old 03-06-2019, 05:00 PM   #8
mongocanfly
When s-k posted that I went looking for it...never did find it...
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 04-04-2019, 01:21 PM   #9
scoots71
Did you find a tire and wheel combo
scoots71 is offline   Reply With Quote
Old 04-04-2019, 01:45 PM   #10
Fuji
No, guess we will have to wait till
Everything is in place and then do all the measurements. Seems strange that as many of these trucks that have been built the info hasnít already been documented. Oh well.
Old 04-04-2019, 02:34 PM   #11
SCOTI
SCOTI's Avatar
No.1 reason is because EVERY truck is different as are most every owners likes. What works for one may not another so you still can't go by the specs Avg. Joe provides. Yes, they can be used as a starting point but you should always measure your exact set-up when determining what can or will work.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-04-2019, 06:28 PM   #12
scoots71
I talked to one guy that has 285 40 18 on a 9.5 rim allthe way around
Old 04-05-2019, 10:19 AM   #13
SCOTI
SCOTI's Avatar
This is what causes confusion & exactly why random numbers don't work. While this combo might have actually been installed on one particular Step Side truck, I know it wouldn't work on MANY others.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-05-2019, 08:47 PM   #14
scoots71
Ok good luck then
Old 04-06-2019, 12:39 PM   #15
SCOTI
SCOTI's Avatar
Ok good luck then
I don't need luck because I actually measure & ask specific questions if needed vs generic 'will they fit' questions. That being said, please don't take offense.
Without knowing the details & having pics of the actual vehicle, it's difficult to validate the combo for a different (the thread starters) truck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-06-2019, 12:47 PM   #16
SCOTI
SCOTI's Avatar
Fugi..... 4/6 drops are mild so there's definitely room for some decent size rubber. My recommendation is to Google 'Hotchkis C10' & do some investigating. I know there are pics out there of multiple trucks running that Hotchkis set-up & they might have their wheel/tire combos posted. Find one you like the appearance of, try to determine those specs & work from there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-10-2019, 03:27 PM   #17
68Stepbed
68Stepbed's Avatar
That's probably me. I have 18x9.5(5.25" bs) on all fours. I did have 285/40/18 tires, but now I'm running 275/35/18. I'm currently using TCI Engineering suspension, but I had this setup with a 4.5/6.75 dropped stock suspension.
The determining factor will be rearend width. I have a 72 rearend, which is wider than the 67-70 rearends. That's going to change your backspace numbers. Also, for what it's worth, the 5.25" backspacing is still a bit too much for a stock stepside bed. 5" bs would've been ideal, but hard to come by in a one-piece wheel.
Again, as SCOTI said, measuring what you have is the best way to know what will and won't fit.
Matt
Old 04-10-2019, 03:53 PM   #18
SCOTI
SCOTI's Avatar
Your truck & '1971_c10' truck were the 1st two I thought of when I opened this thread. Thanks for reinforcing the need to check your personal set-up vs what another truck might have. It can be a frustrating & expensive mistake.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Copyright ©2000 - 2020, vBulletin Solutions Inc.
