Old 01-29-2011, 10:11 PM   #1
madcow75
madcow75's Avatar
Lightbulb Dana70HD Dually disc brakes
I am in the middle of converting my 1976 C30 Dually DRW to rear disc brakes. I have the (Ruffstuff) caliper bracket going to use 76-78 elderado calipers but I cannot remember or find which chevy 3500 Express van rotors to use. I just need the years that are compatible. I think that it was somewhere in the 90's but not sure. If someone know's the years that would be great. Thanks
madcow75 is offline   Reply With Quote
Old 01-30-2011, 12:07 PM   #2
madcow75
madcow75's Avatar
Re: Dana70HD Dually disc brakes
3/4 ton fronts are for single wheel setup but in the rear. I am looking for the Express van rotors for rear for disc setup on my dually. These rotors are very deep like the the deep Dana 70HD drums. Looking for what years rotors I can use?
Old 01-31-2011, 12:54 PM   #3
madcow75
madcow75's Avatar
No replies. No thoughts.
Old 01-31-2011, 02:37 PM   #4
madcow75
madcow75's Avatar
Finally found it 2003 chevy express van rotors
Old 01-31-2011, 04:57 PM   #5
HotRodYJ
HotRodYJ's Avatar
Great info, thanks!
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 01-31-2011, 05:02 PM   #6
madcow75
madcow75's Avatar
Great I am finally happy to re-find it. Glad someone else can use the info.
Old 02-01-2011, 07:49 AM   #7
HotRodYJ
HotRodYJ's Avatar
I've been debating on putting rear disc's on my Dually. These are exactly the rotors that would make my life SOOOO much easier when I do. So thanks again!
Old 04-16-2011, 04:00 PM   #8
502ss
502ss's Avatar
I am very interested!! Any pics yet?
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 04-16-2011, 04:12 PM   #9
madcow75
madcow75's Avatar
No I do not have any assembled parts. It is all riped down to a bare axle at this time. I am going to por15 all parts before assembly. But my frame comes first, I'm doing a ground up restoration. All I have done is some research so far. You can look up www.tmssfg.com , maybe for a liitle help. Here what I have so far 2003 chevy express 3500 rotors, 76-78 Elderado rear calipers for the e-brake. But I have not found anyone using them with a dually swap yet, so I am not 100% if they work or not for clearance issues, most use 73-87 3/4 ton front calipers. But then you have no ebrake, unless you go with a driveshaft e-brake. DIY4x4 rear disc brake brackets. I allready have ruff stuff brackets. Also 1/4" spacers between rotor and hub for perfect caliper centering. This is all with factory 16" steel dually wheels.
Old 05-30-2011, 02:50 PM   #10
jimbonice
jimbonice's Avatar
When you find out if it works, let us know. This would be a great swap.
jimbonice is offline   Reply With Quote
Old 05-30-2011, 02:55 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Pics of the process would be awesome. Sounds like an FAQ in the making.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-30-2011, 09:25 PM   #12
SCOTI
SCOTI's Avatar
When I went to the site to investigate the possibility of a disc swap, I read this set-up was not intended for dual rear wheel applications. Blackbirds does offer GM based Dana-70 & 70U kits.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 10-05-2011, 04:14 PM   #13
truckzilla
truckzilla's Avatar
Hey MadCow, any updates on your Dana 70 conversion? Any photos yet? And you said that the Ruffstuff brackets and calipers, I'm guessing you used the single piston D52 calipers, fit inside a standard dually wheel? Did I get that right?
truckzilla is offline   Reply With Quote
Old 10-05-2011, 09:14 PM   #14
madcow75
madcow75's Avatar
I have the Ruffstuff brackets, but I aborted that mission I purchase all brand new parts for the rear drum dana70hd setup. Upon reading more they did not recommend using those brackets if you were going to be hauling. So that tells me they are not strong enough.
Old 06-15-2012, 05:19 PM   #15
JCampbell
Anybody know of a rear disk kit for dually's?
JCampbell is offline   Reply With Quote
Old 06-15-2012, 05:47 PM   #16
SCOTI
SCOTI's Avatar
http://diy4x.com/cart/index.php?rout...product_id=149
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-15-2012, 06:15 PM   #17
truckzilla
truckzilla's Avatar
Thumbs up Re: Dana70HD Dually disc brakes
You might check out the kit from Blackbird at
http://www.blackbirdscustomtrucks.co...7.html#9dually
And from TSM at
http://tsmmfg.com/2882.htm
I'm hoping to get the same results, but from buying brackets and parts and using the dual piston Wilwood D52 calipers while incorporating a cable operated parking brake at each rear rotor.
Old 06-15-2012, 08:35 PM   #18
JCampbell
Originally Posted by SCOTI View Post
Do you know what rotors they use?
Old 06-15-2012, 08:43 PM   #19
SCOTI
SCOTI's Avatar
I recall they were later model 3/4 ton van fronts or similar & 'single use' (not turnable) application. Check in w rs72z.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-16-2012, 03:31 PM   #20
JCampbell
Hmm. For some reason, I thought you had to use those goofy-expensive Chevy Express rotors w/ the super deep "hub" to be able to use this kit on a dually.
Ex:
Old 06-17-2012, 02:21 AM   #21
SCOTI
SCOTI's Avatar
Ex:
Not sure but you might be correct. Best to ask rs72z....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2012, 03:59 PM   #22
rs72z
rs72z's Avatar
That looks like the rotor i used. I had a complete rear out of a 05 dually truck and i used the rotors off of it on my dually.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 06-19-2012, 05:45 PM   #23
SCOTI
SCOTI's Avatar
Were they part of the 'kit' or ??
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2012, 06:40 PM   #24
rs72z
rs72z's Avatar
I bought the brackets from dyi and used the rotors off a 05 3500 dually rear. The calipers are off of the front on a 85 4x4.
___________________
78 ccsb dually
5.3
4l60e
Old 06-19-2012, 11:34 PM   #25
rs72z
rs72z's Avatar
Ok, not typing on my phone now so i will try and repeat this so it makes sense.
I used the brackets from http://diy4x.com/cart/index.php?rout...product_id=149.
The brackets didn't come with any directions or info, i found the info on another thread on here, by wyattglock i think.
The rotors i used came from a 05 chevy 3500 dually rear that i had already and the calipers are off the the front of a 85 3/4 ton 4x4.
___________________
78 ccsb dually
5.3
4l60e
Copyright ©2000 - 2020, vBulletin Solutions Inc.
