Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 08-13-2017, 04:14 PM   #1776
Hart_Rod
Hart_Rod's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
Originally Posted by 72MARIO View Post
I have the original 2 piece cut down with the small light duty 2 bolt hanger bearing.
Gotcha. What angle do you have at the middle joint (in between the front and rear drive shaft? Theoretically, you want around zero at the transmission to the first shaft and and then 3 or less at the between the first shaft to the second shaft and the opposite from the second shaft to the differential. That's what the guy at the drive line shop told me anyway. My 2 rear angles were good but my angle at the transmission was way out. The only way to make it correct was to raise the transmission (low transmission hump). Unfortunately there wasn't any room to do that. So the only option at that point was the double CARDAN joint. It allows for the angles to be off and helps prevent vibrations. Hope this was somewhat clear. Let me know if you have any other questions.
Rob - http://instagram.com/hart_rod
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
FOR SALE: DBW pedal bracket, Pedal adapter for LS trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=651123
FOR SALE: ChubTubz, Rear tubs for slammed trucks! http://67-72chevytrucks.com/vboard/s...d.php?t=675754
FOR SALE: Hood Brackets, Bolt in hood brackets! http://67-72chevytrucks.com/vboard/s...d.php?t=679945
1969 SuperBurb - 5.3/Magnacharger..http://67-72chevytrucks.com/vboard/s...d.php?t=200387
1968 Farm truck: LS3/6L80/TVS1900: http://67-72chevytrucks.com/vboard/s...d.php?t=358692
1968 SWB - SHIFTED: PB Xtreme DM/LS1/Dakota Digital/AccuAir/Vintage Air/...http://67-72chevytrucks.com/vboard/s...d.php?t=551258
1948 5 Window Chevy http://67-72chevytrucks.com/vboard/s...=122164&page=3
FAQ: http://67-72chevytrucks.com/vboard/f...play.php?f=220
Hart_Rod is offline   Reply With Quote
Old 08-16-2017, 05:13 PM   #1777
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=. So the only option at that point was the double CARDAN joint. It allows for the angles to be off and helps prevent vibrations. [/QUOTE]
So hows it performing?
Tom Vogel is offline   Reply With Quote
Old 08-17-2017, 09:22 AM   #1778
Hart_Rod
Hart_Rod's Avatar
So far so good! I haven't put a lot of miles on it yet as I'm still data-logging and playing with the tune, but the drive train seems pretty smooth. I do need some new shocks and will be purchasing some Ridetech HQs pretty soon.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
