06-02-2018, 12:46 PM | #1 |
Spring Problems
Wow....more problems
1997 GMC Sierra Ext 1965 Mustang |
06-02-2018, 01:31 PM | #2 |
Re: Spring Problems
It’s frustrating, especially at this point, but it’s relatively cheap and bolt on!
06-02-2018, 04:00 PM | #3 |
Re: Spring Problems
Can I just get that one spring or do they come complete?
I guess I should get both sides
06-02-2018, 05:54 PM | #4 |
Re: Spring Problems
If they are breaking they are all due.... I don't think you could buy just a top leaf unless you went to a spring shop.
06-03-2018, 06:51 AM | #5 |
Re: Spring Problems
Any recommended places to buy springs?
06-03-2018, 12:07 PM | #6 |
Re: Spring Problems
If you want used ones I've maybe got some... (depending whether you have 52" or 56" of course.)
They're heavy though, so shipping may be a beast |
06-04-2018, 08:49 AM | #7 |
Re: Spring Problems
Ive bought springs from General Spring KC and Michigan Spring - both seemed to be great springs. Shipping is high but not as bad as you would think.
06-04-2018, 10:47 AM | #8 |
Re: Spring Problems
I got mine from Alcan spring. Made to order.
06-05-2018, 10:49 PM | #9 |
Re: Spring Problems
Main leaf broken......have them rebuilt or buy a different set
06-06-2018, 12:35 PM | #10 |
Re: Spring Problems
I've used these guys twice for two sets of 56" springs. They also sell just the main spring as well. Reasonable with good shipping. Mike
https://www.generalspringkc.com/Leaf...987_s/1823.htm
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
06-06-2018, 12:54 PM | #11 |
Re: Spring Problems
Now I'm wondering if someone intalled the wrong springs way back when.
I'm counting 8 leafs. I don't think I need this many as this is a 1/2 ton short bed 2wd. What spring count should I get?
06-06-2018, 01:05 PM | #12 |
Re: Spring Problems
After measuring the springs, it looks like I'll have to replace with the same type as they measure at 26"x30"
06-06-2018, 01:30 PM | #13 |
Re: Spring Problems
My guess is that it’s a 56” spring (eyelet to eyelet = Big10/HeavyHalf truck)??
06-06-2018, 01:32 PM | #14 |
Re: Spring Problems
Sorry, didn’t see your last post. I removed a couple springs on my 56” springs. Mike
06-10-2018, 10:44 AM | #15 |
Re: Spring Problems
The rear spring set up is set up for 3/4 ton like said heavy 1/2.ton
I had 8 put in one more leaf per side. So if your not going to ever load more then the 1/2ton you could take two leafs per side.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
06-10-2018, 10:51 AM | #16 |
Re: Spring Problems
But doing that....will it change the ride height?
06-10-2018, 12:12 PM | #17 |
Re: Spring Problems
YES but very little. But it up to you it will save you some money.
But if you never going to need the extra load of the extra spring then your wasting money + the ride will be a little smoother I can tell you because with 9 leafs per side much harsher ride unloaded, drives like a caddy when load.
