07-20-2018, 10:18 PM | #1 |
70 C10 rear brake ?
Brakes hung partially - popped petal and they released. Since I have disk in front I expected rear. Pulled hubs today to see what I needed.
Passenger side looked to have a good 20% of lining left. Driver side was so thin that lining was crackled on both primary and secondary shoes. Why would hydraulic brakes wear with so much difference? The pressure should be equal. Passenger drum had almost no wear - driver drum had such a low amount that I am not going to have them turned. |
07-21-2018, 12:53 AM | #2 |
Post Whore
Re: 70 C10 rear brake ?
might have been the way the were adjusted......one tighter than the other and dragging
07-21-2018, 10:26 AM | #3 |
I'd guess the worn out side was working fine, the other had a problem with the self adjuster which kept it from fully functioning. Maybe just corrosion. It happened to me when I had a Waverunner due to backing my rear wheels into the water when I launched it.
07-21-2018, 10:42 PM | #4 |
AcampoDave that kinda makes sense. The adjuster, however, looked OK at first glance. See pics.
07-22-2018, 05:39 PM | #5 |
Is that brake fluid all over it and was it like that when you popped the drum? Also adjusters come in drivers and passengers side. They thread in opposite directions. After all these years, who knows they could be both the same. Edit: having drums turned always improves braking when you remove the "mirror finish" As a bonus your e-brake will stop you better in an emergency. These are the rear brakes.... do it once first class and it'll last a long time. Way longer than fronts do.
07-22-2018, 07:34 PM | #6 |
Active Member
After fighting break problems on my 68 for many years I finally decided to go all out and replace all new parts. I got all new break cylinders, shoes, springs and clips and had the drums turned. I took apart the adjusters and cleaned them with wire brush and coated them with a thin coat of grease.
I also replaced all the rubber hoses -two in front and the one for the rear brakes (I had one collapse on my 69 many years ago and caused the rear brakes to hang). It's amazing the difference it made in braking
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
07-22-2018, 11:25 PM | #7 |
Wet stuff was mineral spurts that I was using to clear off dust. Since there was only 'bout 20% left, I assumed the adjuster is correct but I'll double check when I do that side.
I had switched fronts to disk. |
07-22-2018, 11:28 PM | #8 |
60-66 Nut
You might want to double check that the adjusters are on the correct side, or are correct for the side they are on.
07-23-2018, 08:06 PM | #9 | |
07-23-2018, 08:12 PM | #10 | |
07-23-2018, 11:07 PM | #11 |
Had time to rebuild passenger side today. I found nothing wrong. I was expecting seized or hard to turn adjuster but it rotated freely. It was correct one - marked for right side.
Go figure. I can't remember how long it was since I last relined so if it has the same trouble - I won't complain. |
07-24-2018, 03:21 PM | #12 |
Check the emergency brake cables. The side with the thin linings is probably hanging up.
