Old 02-09-2019, 06:32 PM   #1
mattfranklin
mattfranklin's Avatar
SM465 with M10x1.00 thread for shift knob?
Original shift knob was aluminum and half jammed on when I bought the vehicle.
Shaft measured 0.374 and thread looked very fine so I bought a 3/8-24 nut to test fit. Did not fit.
So I bought a couple of metric nuts: one was labeled M10x1.25 and the other was labeled M10x1.00. The fine threaded one fit perfectly.
Now I cant find any shifter knobs with an M10x1.00 thread.
I'm now wondering of the hardware store bin was mislabeled or if I do really need the M10x1.00 and they are just hard to find.
Any ideas? I have a proper thread gauge somewhere and may need to dig it out.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 02-09-2019, 09:04 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: SM465 with M10x1.00 thread for shift knob?
You can probably run a tap into the existing knob and clean up the threads.
I did that with my MY6 shift knob. The shaft was fine thread and the replacement knob (a transfer case knob) was coarse thread . Ran a tap in it with no problem.
K
Chevrolet Flint Assembly
1979-1986
1986 - Feb 2019
Old 02-09-2019, 09:05 PM   #3
Keith Seymore
Another option would be to drill the threads out and use the appropriate heli-coil insert.
K
1979-1986
1986 - Feb 2019
Old 02-09-2019, 11:06 PM   #4
kwmech
Never seen a metric 465 shifter
Old 02-11-2019, 12:22 PM   #5
mattfranklin
Thanks, guys. Maybe just I'm fooling myself with the M10x1.00 nut. Its dimensions are so similar to the 3/8-24 that it's not even funny. And maybe with a little more chamfer clean up the 3/8-24 will fit.
Old 02-11-2019, 12:28 PM   #6
mongocanfly
A thread gauge is what you need...that 10mm is larger than 3/8...that may be why it threads on so well.....
get a 3/8-24 die and chase the threads and you should be good...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 02-12-2019, 11:33 AM   #7
mattfranklin
I love this board. Excellent info.
I was concerned that if someone had swapped in a newer SM465 it might have had some metric in it, but based on your info and guidance I'll run a 3/8-24 die down the threads. I would have hated to risk doing that if it were really a metric or vice versa.
I think I might already have one in my tool box. I bought a bunch when our local hardware store (OSH) went out of business.
Old 02-18-2019, 01:33 PM   #8
mattfranklin
Thanks for your help, guys!
I ran the 3/8-24 die down the shifter threads this weekend. I was careful to keep it perpendicular, which was kind of hard. It felt a little tight at first and then got easy the rest of the way down. Then I was able to spin a 3/8-24 nut up and down the threads with ease.
Then I ordered a proper round shifter ball. eBay even had one with the correct SM465 shift pattern. I hope the quality is ok, because sometimes eBay is sketchy.
Old 02-18-2019, 06:17 PM   #9
mongocanfly
sweet...glad it worked out for ya
Mongo...aka Greg
Old Today, 02:43 PM   #10
mattfranklin
All is well. Glad I could find one with the shift pattern because I plan to teach family members to drive a stick with this truck.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
