Old 03-24-2014, 10:13 PM   #1
Dads64
Cab Floor
OK guys, I have finally to start working on the '66 cab to go on '64 short step frame. Here a couple of pics of the floors, just wondering how one goes about repairing the firewall portion of the floor. I don't seem to see any panels past the floor. Also, are there panels for the kick panel area by the vents?
Sorry for dumb questions but this is my first try at this.
Jay
Dads64 is offline   Reply With Quote
Old 03-25-2014, 12:18 AM   #2
pdxhall
pdxhall's Avatar
Re: Cab Floor
There are no patch panels available for the firewall portion of the floor. You have to either fab some up with sheet metal or find a donor cab with good metal. You can buy patch panels for the kick panels. From the looks of it you will probably be needing inner and outer rockers and possibly door pillar bottoms which are also available in patch panels. Check through some of the build threads. Alot of us have went through the same thing and worse. Good luck.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 03-25-2014, 01:12 AM   #3
LT1 Burb
LT1 Burb's Avatar
Re: Cab Floor
Might be easier to come and buy my rust free AC cab!
LT1 Burb is offline   Reply With Quote
Old 03-25-2014, 08:26 AM   #4
shortbed70
shortbed70's Avatar
Re: Cab Floor
Fab panels.... There not that hard and can be done in a vise.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-25-2014, 10:07 AM   #5
racecougar
racecougar's Avatar
Re: Cab Floor
Yep, you'll need to make patch panels for the lower firewall. I did the bead rolls first, then worked off them to find my bend lines.
Both sides needed replacement sheetmetal on mine.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-25-2014, 10:25 AM   #6
Dads64
Re: Cab Floor
Funny, I was just reading though your build. It will be rough for me as I haven't even welded since high school (we get into how long ago that was) and have never done it on a vehicle. But it has to get done.
I have noticed that this trans hump in this 66 Cab that I am trying to use to replace my 64 cab is low and does not look to be bolted in. The 64 had a 4 speed in it and the hump was higher and bolted in, is this going to be an issue? I am going auto in the build.
Thanks for all the help guys.
Jay
Old 03-26-2014, 09:25 PM   #7
Jeff La
Re: Cab Floor
You should be fine with the low hump and an auto.
Jeff La is offline   Reply With Quote
Old 04-27-2015, 08:28 PM   #8
tismy65
Re: Cab Floor
What gauge sheet metal did you use for patch panels 16 or 18 ga.
tismy65 is offline   Reply With Quote
Old 04-27-2015, 10:19 PM   #9
padresag
Re: Cab Floor
this has been posted several times before and unfortunately we do not have Wood here any more to put it in the FAQ section. scroll down and some more on the next page
http://directsheetmetal.com/Store/in...ort=20a&page=2
ron
padresag is offline   Reply With Quote
Old 04-28-2015, 06:07 AM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Cab Floor
Some simple leaf brake work, then a hard wood die and a big hammer made this drivers side replacement piece.
Old 04-28-2015, 08:34 AM   #11
pimpston65
pimpston65's Avatar
Re: Cab Floor
who made that panel? i need that piece bad!!!
pimpston65 is offline   Reply With Quote
Old 04-28-2015, 09:14 AM   #12
Softpatch
Softpatch's Avatar
Re: Cab Floor
I wish I had those skills Nice work
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 04-28-2015, 04:47 PM   #13
aerotruk63
aerotruk63's Avatar
Re: Cab Floor
I made that panel pimpston65, I'm not all just good looks you know! lol
Old 04-28-2015, 04:52 PM   #14
pimpston65
pimpston65's Avatar
Re: Cab Floor
so how much, good looking to make me one???
Old 04-28-2015, 09:26 PM   #15
racecougar
racecougar's Avatar
Re: Cab Floor
See the link in post #9. That piece is available now.
Old 04-29-2015, 12:41 PM   #16
russellrox
Re: Cab Floor
does direct sheetmetal ship to saskatchewan Canada.
russellrox is offline   Reply With Quote
Old 04-29-2015, 12:55 PM   #17
russellrox
Re: Cab Floor
guess I just answered my own question, I just ordered a set of toeboards, 75.00 shipping to my door. Thanks for the link racecougar.
Old 05-01-2015, 11:18 AM   #18
Jeff La
Re: Cab Floor
Old 05-01-2015, 12:34 PM   #19
aerotruk63
aerotruk63's Avatar
Re: Cab Floor
Originally Posted by Jeff La View Post
Laughing at my looks?
Old 05-01-2015, 12:39 PM   #20
pimpston65
pimpston65's Avatar
Re: Cab Floor
your a good looking french man, im not above saying nice things bout a man!!!
Old 05-01-2015, 01:00 PM   #21
aerotruk63
aerotruk63's Avatar
Re: Cab Floor
lmao!!!
Old 05-01-2015, 09:39 PM   #22
Jeff La
Re: Cab Floor
Hell no. I'm waiting to see if it works, I need that floor also.
Old 12-20-2015, 01:17 PM   #23
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Cab Floor
ron
Yeah, he did a lot of work on the FAQs, and kept them up to date. He doesn't hardly post over at Classic Forums either.
I came across this thread because I'm looking for replacement cab floor pan mounting washers with the cup to recess the mounting bolt head.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-20-2015, 01:26 PM   #24
padresag
Re: Cab Floor
those washers shouldn't be to hard to make. you would just need some heat and a form of sorts to be able to stretch the metal with a hammer or what ever will do the job
ron
Old 01-19-2016, 09:51 PM   #25
LostMy65
LostMy65's Avatar
Re: Cab Floor
Found these for $10 shipped.
Strut caps.
