07-16-2018, 12:46 PM | #1 |
Re: 1972 SWB Build
Well, it's back on the ground!! It's been a long time coming. Next up is rolling it over to the lift so I can run all new brake lines, install the front sway bar and get this bad girl back on the road!
07-17-2018, 12:31 AM | #2 |
Re: 1972 SWB Build
Very nice. Always a good feeling to get them off the lift and see the ride height.
07-17-2018, 11:08 AM | #3 |
Re: 1972 SWB Build
Yes it is! Thanks!
07-18-2018, 12:14 PM | #4 |
Re: 1972 SWB Build
Pushed it over to the lift this morning. Now it’s time to run those new brake lines!
07-21-2018, 03:17 PM | #5 |
Re: 1972 SWB Build
Spent some time the other night working on the truck. I removed all of the old brake lines and ran the new set. I can't say enough about how well the Inline Tube kit fits. Like a glove. I've got to clean up the old unions and tee to finish it up as well as figure out what I am going to do with the axle lines. I'm going to fix the broken trans mount today (doh) and install some heat shield on the lines. Getting closer!
07-23-2018, 02:31 PM | #6 |
Re: 1972 SWB Build
Replaced the broken transmission mount only to find the trans is sitting too high. I ordered a new crossmember from ECE that should help. The problem I was running in to was the driveshaft was only 3/4 away from the trailing arm crossmember. Couple that with the wacked out u-joint angles I was getting, it should be an easy fix.
Don’t look too hard at that leaky trans. It’s coming out this winter. |
07-24-2018, 10:24 AM | #7 |
Re: 1972 SWB Build
A couple more pieces of the puzzle arrived this morning. New cross member will be here Friday.
