08-06-2017, 04:46 PM | #1 |
Headlights Stopped working
Hey Chevy People,
My headlights on my '72 c10 took a dump all of a sudden last night. The toggle switch looks good, and other lights (dome, parking, etc.) work fine. Have any of you got an idea what might have happened/what to do? |
08-06-2017, 05:20 PM | #2 |
Re: Headlights Stopped working
use a tester for power at the socket.
If you have power at the socket then it's a fault in the ground Bad ground is often the culprit. Also check socket plug connector for corrosion. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
08-06-2017, 05:21 PM | #3 |
So you have a toggle switch?
You should use a tester to see if you have voltage at the headlights and along the wires that go to the headlights. |
08-06-2017, 06:42 PM | #4 |
My headlights [Hi + Lo] went out when my dimmer switch went bad. That's the toe-operated one on the floor, left of the clutch pedal. Or Brights/Dim switch.
R + R'ed the dimmer switch and the lights worked normal again.
08-06-2017, 08:42 PM | #5 |
20' Daredevil (Ret)
Could be any number of things but the most common problem seems to be the dimmer switch or the wiring / connector at the dimmer switch.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-06-2017, 08:51 PM | #6 |
Welcome to the boards!
Multi-meter's are your best friend, but start in reverse from ground then chase positive! Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
08-06-2017, 09:12 PM | #7 |
Where's my beer?
A new dimmer switch fixed my headlights that stopped working years ago.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
09-25-2017, 09:20 AM | #8 |
Thank you for your advice, it was the dimmer switch. The wires under the carpet looked like a birds nest, a little TLC and the lights work great. THANK YOU
