09-18-2018, 12:17 AM | #1 |
500 caddy or 455 olds?
Which one should I get?
I found a guy selling one of each. A 75 rwd 500, and a 73 455 from a 98 that will become derby cars. Either will come complete air cleaner to pan, fan to yoke and wiring. Neither has smog stuff. I've heard the caddy run long enough to drain the carb, and it sounds good. Trans wouldn't go in gear, fluid too low? Olds not running yet, but he will make it run and let me hear it. So the caddy is cheaper upfront, but will need more parts/work to fit in my truck. The Olds should just drop right in once the frame stands are moved to the right spot. So, assuming both run equally well, which one would you get and why? Please don't suggest LS, not happening for many reasons. Thanks for reading. |
09-18-2018, 04:02 AM | #2 |
Re: 500 caddy or 455 olds?
500 caddy
09-18-2018, 04:20 AM | #3 |
Dr. Oldsmobile says....
not sure what's out there for big block cad aftermarket, but used to be lots of stuff for the olds.. good luck either way!
I started out with nothing - and I still have most of it |
09-18-2018, 06:57 AM | #4 |
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-18-2018, 08:21 AM | #5 |
500 Caddy all day...
09-18-2018, 01:26 PM | #6 |
if they both run equally well....same price...here would be my opinion
more displacement, and torque = Cad wins lighter weight = cad wins trans/convertor bolt pattern = both are same = tie (both are different than chevy) fitment to truck = Olds may have advantage (rear sump pan needed for caddy). If you can find a rear sump caddy pan, then it would be relatively simple to put the cad in there I believe. They are both very wide units LOL
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
09-18-2018, 03:05 PM | #7 |
Who Changed This?
Are you getting either engine after the derby is over? It's likely to be toast after a crash that destroys the radiator and the crowd wants to see the thing roll to a stop in a cloud of smoke. I'd want to hear it run after the wreck.
09-18-2018, 03:19 PM | #8 |
Plan on putting one in your pickup??? I'm guessing?
I believe the Cad engine is physically somewhat larger, may or may not be problem in pickup install. Either would be good... |
09-18-2018, 06:41 PM | #9 |
Caddy for sure. Put one in a 49 GMC 30 years ago had the power to pull anything and didn't get horrible milage either.
09-18-2018, 08:24 PM | #10 |
09-18-2018, 08:29 PM | #11 |
I put a '72 455 Olds in a '79 short Silverado and it was AMAZING how much gas it burned. Serious tire burner too.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
09-18-2018, 08:31 PM | #12 |
Thanks for the replies, everyone! Looks like I'm getting the caddy...
09-18-2018, 08:33 PM | #13 |
09-18-2018, 11:24 PM | #14 | |
Who Changed This?
The only experience I have with an engine locking up is way back in the mists of time (about '71) when one of my little sisters wrecked her '62 Nova convertible (45 minutes after getting her license!). We went to get another Nova with a rod knock and proceeded to drive it home (35 miles!). It got louder and louder as we drove, and it finally threw a rod, with that piston exiting the side of the block. I just kept driving it until it seized. Then my mom took me home to get the tow bar. My younger brother (who did not have a license at the time, but it was on a dirt road) had stayed with the car to keep it from getting impounded while we were gone. When we got back, it was about half a mile closer to home, because once it cooled off, it would run again. Tough little I6 Chevy. Fun fact- my dad asked me why I didn't just pull the plug wire off the affected cylinder. I was thunderstruck. We would have made it home with a lot less trouble, but I just hadn't thought of it.
09-18-2018, 11:54 PM | #15 |
Cool story! And yes, Chevys are tough! I've never managed to seize an engine, I take pity on it and shut down before that happens.
That derby guy did show me his current car - ls powered. He said he had the ecm reprogrammed to compensate for overheating - fuel and spark curves adjust to help it run cooler. Idk the specifics, but I think the hotter it gets the richer it goes. Computers aren't my thing, that's why I want an old school big block. |
09-19-2018, 12:05 AM | #16 |
T.
. Def the 500 Caddy! Top it off with one of the available EFI systems and don't look back!!!!!!! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-19-2018, 10:37 AM | #17 |
I would go for the big block Chevy.
09-19-2018, 10:48 AM | #18 |
Pontiac, 428.....
09-19-2018, 11:15 AM | #19 |
^ yes! Poncho power
09-19-2018, 08:20 PM | #20 |
09-21-2018, 07:47 AM | #21 |
blood type; Retumbo
Longhornman did a writeup on stuffing a big cad in our trucks.
Dimple (sister sledge) the driver firewall. Rear sump pan and pickup tube Square body towers and cad mounts. Just use a light foot in winter. The big caddy makes big torque, NOW!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-21-2018, 10:16 AM | #22 |
If I cold get both,I would do that.They're both bop bell housing pattern.you could have one In your truck tearing it up,and one on a stand waiting to drop in.
09-21-2018, 10:19 AM | #23 |
If you want a 4 speed though,I think old's is the way to go.caddys are only automatics.
09-21-2018, 05:11 PM | #24 |
Go Pack Go!
Yep. Couple other members use the 472/500 Caddie powerplant. I also recommend Caddie over 455.
09-21-2018, 07:15 PM | #25 |
Who Changed This?
I know that one could get a manual four speed in a Calais coupe, back in the late '60s and early '70s. RARE. All the BOP bell housing and clutch parts will fit. That would be a pretty cool ride!
