Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 09-06-2017, 02:23 PM   #1
85raiderburban
85raiderburban's Avatar
speedometer reading slower than actual speed
i swapped a '95 GMT gauge cluster into my squarebody. Everything is working great minus the speedo. i have the VSSB I yanked from the same truck and wired it without an ECM. My 33 inch tires (295/75/16) and 3.21's out back equal an input ratio of 0.605xxx. I calibrated the VSSB to that nearest jumper settings (0.604492) found on the chart at http://tbichips.com/?page_id=504. BUT the speedo reads 5 mph slower than actual speed.
i.e. If im going 40 on the GPS, the cluster speedo reads 35.
*UNDER CONSTRUCTION*
'80 Suburban C20 (C6P) (Silverado) 31's F / 33's R
- '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '96 4L80 TSS / 14B FF 3.21 gov lock / '95 GMT400 gauge cluster
85raiderburban is offline   Reply With Quote
Old 09-11-2017, 08:37 PM   #2
85raiderburban
Arrow Re: speedometer reading slower than actual speed
UPDATE!! i got it working with the 0.632 input ratio ont he chart. Its dead on all the way thru, matching my GPS speedo. KEEP IN MIND for those who are doing taller gear swaps and keeping bigger than factory tires, that the calibration calculator is not always accurate. Try different ones on the chart whether its a lower than your input OR higher.
In my case:
0.591xxxx - 7-8 mph slower
0.598xxxx - 5 mph slower
*0.604xxx - closest to my calculated input (3.21s and 33.42 inch tires--> 0.605) read 5 mph slower than GPS
0.611xxx - 0-20 dead on, at 25 mph went 5 mph slower
0.618xxx - read 7 mph too fast
0.625xxx - read 5 mph slower
*0.632xxx - correct reading, dead on with GPS and school zone speed sensor.
Now at 0.632xxx, the CALCULATOR specs are off on either rear gear or tire size. 32.24 in. tires/3.21's ***OR*** 33.42 in. tires/3.35s. I know damn well I have the factory 3.21's out back, so just a warning for those who get the calculator giving ratios that are off compared to your trucks specs. Keep trying them and mark em down 'till you get it right. Good luck eveyone.
Old 09-12-2017, 04:47 PM   #3
sntrym95
sntrym95's Avatar
Yeah I've found that chart isn't completely accurate too. You can install the jumpers instead of having to resolder that way you can swap tires and just flip the switches.
Mike
Toy list:
1995 C1500 Ext. Cab 5.7
1995 GMC Yukon 4dr 2wd 5.7 Vortec conversion, AAM TracRite, Lincoln Mark VIII fan conversion
1979 Mako 23 CC
sntrym95 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
