Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 08-17-2017, 10:13 PM   #1
Brad54
Brad54's Avatar
Best way to lower 3500 dually?
What's the best way to lower a '96 Dually (King cab long-bed), without using air bags?
I don't want to lay it on the ground or anything ridiculous, I just want to drop it a "reasonable" amount, and still be able to haul and tow with it, and not deal with bump steer.
Suggestions?
(companies and components would be appreciated!)
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
Nostalgia Altered drag car with 2x4 FE Ford.
'57 Chevy 2dr 150 wagon gasser
'76 Power Wagon daily driver
'56 Chevy 2dr basket case
'54 Buick Special
'73 Duster on a rotisserie
Hi, my name is Brad, and I have a problem!
Brad54 is offline   Reply With Quote
Old 08-18-2017, 08:52 AM   #2
mountie
mountie's Avatar
Re: Best way to lower 3500 dually?
Contact, Bell Tech, and they will give you a list of truck shops.
When I lived in Southern California, I knew of a few good shops that "slightly lowered" some 4-door dually's that towed trailers for F1-Tunnelboat racing boats and Ski racing boats.
'70 GTO Midnight Blue
'73 Chevelle Malibu Silver
'88 GMC Sierra SLE Camper Pkg 375,000 & still going!
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'96 Honda 550
'86 Yamaha FZ750
'86 Yamaha FJ1200
mountie is offline   Reply With Quote
Old 08-18-2017, 06:44 PM   #3
Terrick down Under
Terrick down Under's Avatar
G'day, this is my dually. It has been working in paddocks and towing down highways for over 12 years now.
4" drop spindles in the front. Then the front of the rear spring mounts were moved higher on the chassis rail. Long shackles simply bolted in. A set of Rancho 9000 adjustable shocks and it rides real smooth and handle well also.
Name:  rear suspension.jpg
We often load up the 2700lb truck camper and head out and it goes well.
although I have been working on a custom set of air bags, so that when backing up to a trailer I simply deflate and then raise when under the hitch, just because I am lazy and it looks so cool.
Terrick down Under is offline   Reply With Quote
Old 08-18-2017, 07:40 PM   #4
mountie
mountie's Avatar
Nice ... I can bet you have some long drives down there!!
'96 Honda 550
'86 Yamaha FZ750
'86 Yamaha FJ1200
Old 08-19-2017, 02:55 PM   #5
Tom
driving is in my blood
Tom's Avatar
Slam it down and add air helper bags for load capacity. Its the only way to go.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Old 08-22-2017, 01:18 AM   #6
Brad54
Brad54's Avatar
The thing I don't like about airbags is if something fails, you're stranded with a collapsed bag.
I'd rather just lower it mechanically and be done with it.
'54 Buick Special
Old 08-22-2017, 01:17 PM   #7
SCOTI
SCOTI's Avatar
While I get your point, an air bag is no different than a tire, starter, water pump etc.... Anything can fail (especially if not installed correctly). A simple AOL set-up installed correctly will be trouble free. I've had them on multiple trucks that pulled trailers & never had an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 08-22-2017, 05:11 PM   #8
Terrick down Under
Hey, Scott is taking you to your next step. You will love the AOL set up for a number of reasons. And then you can have both worlds of driving without many of the bad points.
EG, when I back up to a trailer I just air out completely and reverse, as soon as the ball is under the hitch I air up. It is so handy. I have a cheap camera just on top of the licence tag and can see the hitch perfectly.
Have a thought about this,, you can do it in two stages as your budget allows!
This is the pic of my little trailer hitch and the truck camper.
Old 08-23-2017, 01:25 PM   #9
Tom
Tom's Avatar
Thats why you use helper bags. They only get air when there is a load in the bed. Unloaded your riding on leaf springs. Loaded you have springs plus bags. Bag fails and you still have springs, just less travel.
Old 08-23-2017, 05:42 PM   #10
Terrick down Under
Yep, some places call them "load lifters", or "load levellers". My first set was a "slam bag setup". They were helpful in making up my mind as to what to do.
Old 08-23-2017, 06:47 PM   #11
Brad54
Brad54's Avatar
Okay, that makes more sense to me! I thought you were talking about full air ride.
So what are the best components to lower it?
I'm most concerned about the front suspension, in terms of bump steer, and camber/tire wear.
Back is easy: only have to worry about maintaining pinion angle. Might have to C-notch, but the options are flip kit or new hangers. That's easy.
'54 Buick Special
Old 08-23-2017, 08:26 PM   #12
Tom
Tom's Avatar
Spindles and coils for 1/2tons, but I'm not sure with 1tons. Never had any front end issues from lowering with several trucks.
Old 08-23-2017, 09:37 PM   #13
Terrick down Under
Spindles first up front, then if you need a bit lower then you know how much. Buy well known brands and you should be ok. If the top arms need it, you can buy 1 degree offset bushes. I have them in our daily and are very happy.
If you are towing then buy an engineered notch setup, because when you cut the rails it can weaken them, if not done properly. JMHO.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
