Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-15-2015, 12:54 AM   #276
w00dst0ck
w00dst0ck's Avatar
Re: Color Wiring Diagram FINISHED
For all the guru's, PO put a HEI in my '70. It's wired to the 12P, but it's constant hot for some reason. Put a new ignition switch in the truck and still the same issue. Traces back all the way to the switch. Also currently the unfused ignition slots and the fuse above are constant hot.
Any suggestions? I'm tempted to just run another switched power wire, but that doesn't explain why I'm getting a constant hot.
w00dst0ck is offline   Reply With Quote
Old 06-04-2015, 12:36 PM   #277
HoustonGuy
can someone email me a copy? cavazosmark@hotmail.com
HoustonGuy is offline   Reply With Quote
Old 08-25-2015, 01:14 PM   #278
asesapie
The diagrams are great but they aren't for a GMC with the four eyes up front and AC. Anyone have a diagram for a '68 GMC with factory AC?
asesapie is offline   Reply With Quote
Old 09-30-2015, 01:22 PM   #279
onetonwrecker
onetonwrecker's Avatar
Hey could I get an email of the larger version please chris_san2011@yahoo.com
onetonwrecker is offline   Reply With Quote
Old 09-30-2015, 03:07 PM   #280
jimbosprint
jimbosprint's Avatar
I spent some time (a lot of time actually) re-drawing this in Adobe Illustrator so everything would be easier to read. There are a couple minor edits based on what I have found in my two trucks.
Send me a PM with your email address if you would like me to send it to you.
jimbosprint is offline   Reply With Quote
Old 10-01-2015, 02:24 AM   #281
sharkskinman
Email me the actual files??
Spoonpappy@gmail.com
sharkskinman is offline   Reply With Quote
Old 10-23-2015, 04:42 PM   #282
70gmc4d
Originally Posted by boundstaffpress View Post
V8 engine and cab
Link for the largest version
4200x2550
I don't see the three wires to the trany. I see the one green and one black to the reverse switch. My 70 GMC has three wires, dark green and light green to the switch and the black wire I just assume is a ground. But you know what they say about assuming. Thanks for the diagram it helps a ton!
70gmc4d is offline   Reply With Quote
Old 10-24-2015, 02:48 PM   #283
chuchito
I have a 1972 GMC suburban, and the wiring is driving me crazy. The diagrams I found on here look similar to what I see under the hood but not exactly. Also, I don't see the blue wire that is supposed to be to the oil pressure on my harness but my guage cluster does have a oil pressure guage. The engine harness actually only has 5 wires. I unplugged it and looked at the female plug on the firewall and it also only has 5 inserts. The five wires I have are the tan, dark green, purple,pink, and brown with white. Can someone chime in?
chuchito is offline   Reply With Quote
Old 11-02-2015, 03:11 PM   #284
TOYDOC
TOYDOC's Avatar
Thank you for taking the time to make a diagram like this! if possible could you e-mail me a copy at ctoydoc@gmail.com
Thank you!!
TOYDOC is offline   Reply With Quote
Old 11-02-2015, 03:32 PM   #285
70gmc4d
My 70 GMC has a mechanical oil pressure gauge that is plumbed in the block next to the distributor. And the 70 gmc has 4 headlights up front.
Old 11-02-2015, 10:43 PM   #286
chuchito
Maybe that's how mine is too. There is a metal line that looks like it would go next to the distributor.
Old 11-09-2015, 10:15 AM   #287
70gmc4d
Just a heads up I'd anyone else had the same issue. I did ground the black wire to the fire wall and when I fired up my truck this weekend the backup lights work awesome.
Old 12-05-2015, 01:46 AM   #288
DBear
DBear's Avatar
on this diagram, is the alternator on the driver side, labeled " A.C.F GEN R....or something like that?
DBear is offline   Reply With Quote
Old 12-05-2015, 01:54 AM   #289
DBear
DBear's Avatar
I too would like one emailed to me at twbailey75@yahoo.com. Thanks
Old 03-10-2016, 10:04 AM   #290
oneshot
oneshot's Avatar
Would you email me the files-oneshot@lakeland.ws.
Thank you,
Scott
oneshot is offline   Reply With Quote
Old 03-20-2016, 03:39 PM   #291
flykelley
Active Member
Hi Can you please email me a copy also?
flykelley930@mac.com
Thanks Mike
flykelley is offline   Reply With Quote
Old 04-12-2016, 04:07 PM   #292
cagodinez
cagodinez's Avatar
Can you please send me a copy at
alonzo_51@yahoo.com
THANK YOU!
cagodinez is offline   Reply With Quote
Old 04-14-2016, 12:06 AM   #293
jrock51
can I get a copy as well please?
justin_heil@hotmail.com
jrock51 is offline   Reply With Quote
Old 04-14-2016, 11:41 PM   #294
rsgt
rsgt's Avatar
I would like one please. fgsltwthg@aol.com
rsgt is offline   Reply With Quote
Old 04-26-2016, 07:05 PM   #295
Foot Stomper
Foot Stomper's Avatar
Just scanned the pages looking for a wiring diagram for the 1959 GMC.
Does anyone have? I might even make a Chevy one work too...
TIA
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 07-17-2016, 09:52 AM   #296
Jaik
Does anybody have a diagram for a 57 apache? I bought a new harness with updated fuse box kit. Ive got the basics hooked up. The motor runs again. I can figure it out but a reference would make it easier.
Thanks guys
Jaik is offline   Reply With Quote
Old 08-22-2016, 01:33 PM   #297
cpnbnanamn
Did a high-res version ever get posted anywhere? Also, can I assume the diagram is the same regardless of the engine?
cpnbnanamn is offline   Reply With Quote
Old 11-18-2016, 10:34 PM   #298
396C-10
Re: I suck at reading wiring diagrams..
Originally Posted by Rocmonkey View Post
I have read a bunch of your posts/replies and DANG! you are one smart feller! I wish I knew 1/10 of what you know just about wiring. Thanks for the advice- I've been using it secretly (or, trying to).
........... Meee Toooo!
396C-10 is offline   Reply With Quote
Old 12-14-2016, 12:00 AM   #299
garciajulian
garciajulian's Avatar
Can I get a digram to Please sent to garciajulian@grandecom.net Thanks
garciajulian is offline   Reply With Quote
Old 12-24-2016, 10:28 PM   #300
BronzeGMC
BronzeGMC's Avatar
Please copy sent andy.j.bock@gmail.com
Thank you
BronzeGMC is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
