Old 01-01-2019, 02:06 PM   #1
3x2GTO
wholesale lot find
Sunday night my wife and I were cruzin the back of the lot a our local FORD dealer and ran across this burb in the wholesale corral, it was scheduled to go the junk auction this Week. 1986, C20, 96,000 miles, 454, auto, 14 bolt posi, buckets, console, Z barted when new, not much rust, just tired old burb. $3,000 on the window, I bought it yesterday for $2K, ran great on the way home. I'll use it for parts to get my 85 K30 further along. Here's a picture of the beast.
3x2GTO is offline   Reply With Quote
Old 01-01-2019, 02:10 PM   #2
3x2GTO
Re: wholesale lot find
The glove box tag read 4:10 trac lok, but when I jacked up the rear end and spun the tires, they went opposite directions, guessing the clutch's are bad or the rear was replaced?
Old 01-02-2019, 05:06 AM   #3
AJC
It's an open diff till rear wheel speed difference reaches 120 rpm, then it will engage. Easiest way to tell is to do a burn out on pavement. 2 marks means it works.
AJC
AJC is offline   Reply With Quote
Old 01-02-2019, 09:27 AM   #4
3x2GTO
Ok, I'm used to the 10-12 bolts in chevelles, camaros etc.. where both wheels will spin the same direction when the rear is on a jack. Thanks for the info.
Old 01-02-2019, 11:59 AM   #5
sweetk30
sweetk30's Avatar
trucks got a GOV - LOC unit .
unless military truck only they got a full detroit locker . the blazer also got the GOV - LOC unit . blazer also only open front . some pickups could have got the trac-lok unit that dana offered . its a light duty posi not as beefy as the POWER-LOK posi tho .
i my self have tried 3 options in the rear of 1 specific truck with the same tire combo . open / gov-loc / detroit locker. i live in the snow belt of upstate ny / pa area . i prefer the gov-loc unit for a 14ff rear my self . hard core off road its might be a detroit but if i was doing all the work i would just toss in a ARB air locker get the best of both on-road and off-road traction .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-02-2019, 06:29 PM   #6
71suburban/70CST
LMK if you decide to sell this thing, I've been looking for one of these.
Justin
71suburban/70CST is offline   Reply With Quote
Old 01-02-2019, 11:41 PM   #7
3x2GTO
[QUOTE=71suburban/70CST;8418660]LMK if you decide to sell this thing, I've been looking for one of these. I'm still undecided if I should add it to my K30 or not, but I plan to start parting the burb at the end of the month. It'd be expensive to ship.
Old 01-03-2019, 11:37 PM   #8
AJC
Just in case you're thinking of swaping rear ends. There suburban never got a full floating rear end only semi floating.
AJC
Old 01-04-2019, 12:15 AM   #9
3x2GTO
If it's a semi floater, I won't be swapping mine out. I've parted and owned quite a few K20 pickups, but never had a gov lok to sell. What's it worth?
Old 01-04-2019, 12:49 AM   #10
86454k30
86454k30's Avatar
Not true, all big block 2wd suburbans and pickups got full floaters.
86454k30 is offline   Reply With Quote
Old 01-04-2019, 08:49 AM   #11
3x2GTO
It has mags with center caps on it now, I'll pull a wheel tomorrow and post results. Thanks!
Old 01-04-2019, 12:32 PM   #12
sweetk30
sweetk30's Avatar
no need here is the 14ff cover shape .
Old 01-06-2019, 12:06 PM   #13
3x2GTO
Here's what I have, I tested it out today in the dirt, it leaves 2 marks every time.
Old 01-08-2019, 03:30 PM   #14
AJC
Well I learned something new. Sounds like the gov lock is still there. Are the 2 wheel drive and 4 wheel drive axles the same width? That would be the next question.
AJC
Old 01-08-2019, 11:48 PM   #15
3x2GTO
As far as I know they are, I've sold quite a few 73 - 87 rear diffs from 2 and 4 wheel drive pickups, no buyer ever measured or mentioned a difference. I'll measure this weekend and post results.
Old 01-09-2019, 11:03 AM   #16
sweetk30
sweetk30's Avatar
2wd and 4wd same width . just shock mounts flip flopped and if truck axle 3/4 is the same as 1/2 ton on spring spacing and 1ton the leafs are sucked in a little so spring pads would need to be moved if swapping to a 1/2 or 3/4 ton frame.
Old 01-09-2019, 11:52 PM   #17
3x2GTO
Man, you know some stuff!!! Thanks for your help on this. Probably going to put the 454 in my 76 C20, should be a straight forward swap correct? Just a matter of moving frame brackets, springs etc from the C20 burb to thw C20 pickup?
Old 01-10-2019, 03:23 PM   #18
sweetk30
sweetk30's Avatar
i know a little bit
