05-14-2017, 10:00 AM | #1 |
Do the "CS" style alternators fit our stock brackets?
Not really an electrical question, hence the post here.
I know the wiring is different, but will a CS144 alternator physically fit the stock brackets on a (short water-pump) 350SBC? I've read that these alternators are bigger externally than the stock alternators, but couldn't find anything about if they fit (without mods) after a search here. Thanks!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
05-18-2017, 12:36 AM | #2 |
Re: Do the "CS" style alternators fit our stock brackets?
I tried without any luck on a 68 c10, had to get a custom upper bracket and used a 71-72 lowee bracket to tie it to the head. i dont even think alan Grove makes a cs 144 compatible bracket. My custom upper was just a long thin 1/4" piece cut into a slight boomerang. Nothing fancy.
05-18-2017, 11:19 AM | #3 |
CS130 will, you just have to get the right clocking. Not a 144, but I've used a couple and had good results. I did do the iceberg conversion on them just for insurance since the rear bearing is a weak point.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
05-18-2017, 11:46 AM | #4 |
Old member
Late model alternator with factory brackets.
Also a factory truck bracket setup on a 64 SS Impala motor with a 94 amp alternator..
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-18-2017, 10:46 PM | #5 | |
CS130 - 140amps
05-19-2017, 06:41 AM | #6 |
Old member
Unless you have some need for the higher amp alternator there is really no need for it. If you have a high power stereo competition system then yea but for most trucks the 94 amp is more than enough. They bolt right in and if you buy the right one it hooks up just like the factory one.
I have done several of these upgraded alternators and re do the wiring so they look pretty much factory.
05-19-2017, 10:53 AM | #7 |
I'm a big fan of the 12SI as well (321-266). It does max out at 94A, but that's still a lot of amps. You could weld with your headlights on.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-19-2017, 11:36 AM | #8 | |
But the Cap and the Optima may be of some assistance, along with the fact that the ignition is the only other thing requiring energy while driving... I have a nice 1-wire that has been laying around forever cause I have not had the need to install it. Brand new alternator, a little beat up from being moved plate to place though...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-19-2017, 12:41 PM | #9 | |
Old member
In my opinion a one wire alternator isn't as good as most think. At idle it's not even putting anything back into the battery unless it's been modified even more. Mad electric is very helpful on this subject.
05-19-2017, 05:17 PM | #10 |
Msgt USAF Ret
Andy this thread has puzzled me since I haven't heard of any problem mounting the CS 130 or the 144 in the stock mount. The AD 244 is a different story because it is a bigger body and the mount has to be modified. You wouldn't need that one unless you were running bags and a huge amp though.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-19-2017, 10:20 PM | #11 | |
Old member
05-21-2017, 08:42 PM | #12 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
05-21-2017, 09:56 PM | #13 |
Old member
What do you need man? Between Vett and me we can talk you through it. It's pretty simple really.
Trouble with your truck lights dimming are music fading in and out? Chances are the 37 amp alternator isn't putting enough amps out to power the system. The fix is pretty simple though. a 95 Buick Riviera 94 amp alternator The pictures say it all. If you want to clean the wiring up even more just strip the tape off and run the wires straight to the alternator. Then take the old external voltage regulator out of the truck and toss it!
01-07-2021, 12:02 PM | #14 |
Mr. Cheyenne
your photo, shows 12:00 example but the 12SI on O'Riley's is clocked at 9:00. Though it is for 1985 Buick Riviera and not a 95 Buick Riviera from your post.
Edit: if I am l am looking at the stock alt correctly, the connect is at 12:00... so that is the better "fit" I am guessing?
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 01-07-2021 at 12:09 PM. |
01-07-2021, 12:23 PM | #15 |
Carpe manana
Here’s the internally regulated alternator on a former Blazer of mine. Bolts right in and I used the plug and play adapter from AAW. Clocked at 3:00 I believe: https://www.napaonline.com/en/p/RSE2134356
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 01-07-2021 at 12:24 PM. Reason: Added |
01-07-2021, 05:56 PM | #16 | |
Old member
The 10 years difference in year model is what is wrong. GM changes things in 10 years. If you get the 95 it will bolt right in.
01-08-2021, 02:11 PM | #17 |
I just swapped to this one 2weeks ago. worked great with my stock bigblock brackets. Was Clocked correct, 105 amp. Had to get a different plug with a resistor and bypass the regulator. Off of a 89 Pontiac safari.
Keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-08-2021 at 03:04 PM. |
