02-05-2018, 12:37 AM | #26 |
Re: New to squares
mongocanfly, point well taken.
I live out in the Shenandoah Valley in Virginia (where they say, y'all) but often travel to Washington, DC for work, so I fully understand your point. Washington, DC. To small to be a state, to large to be an insane asylum! Enjoy, |
02-05-2018, 01:08 AM | #27 |
Re: New to squares
I'm kind of forced to take the interstate between home and work so going slower isn't an option. Thanks for the suggestions though.
02-07-2018, 10:09 AM | #28 |
Re: New to squares
These trucks were not really designed to drive at a sustained 80 mph cruising speed. With an anemic 350 engine in a lifted 4x4, the engine will be close to maxed out at 80 mph. I would look into installing a larger engine like a Cummins 5.9 turbo diesel or a 8.1 Chevy gas engine. The 8.1 will still get poor fuel at 80 mph but you would have some throttle to spare while the Cummins will still get around 17 mpg at 80 mph. I would also get rid of the lift and get some tires rated for high speeds. Having a blow out at 80 mph in a lifted truck is not fun and sometimes fatal. Also look into upgrading the brakes. Convert to hydroboost and rear disk brakes.
02-07-2018, 10:17 AM | #29 |
Re: New to squares
Engine swap is a super expensive, time consuming option. I would drop the lift to 2.5" and then if absolutely necessary, drop the tire size to 31" or 32". Otherwise, I'd just drive it as is.
If it was me, I like the look of 33" tires with a 2.5" lift vs. a 4" lift. I personally think the 4" looks too high for me. This does look like a 1/2 ton truck (6 lug wheels), so should have the 4 speed OD, 700R4 tranny.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
02-07-2018, 11:23 AM | #30 |
Re: New to squares
Engine swap is an expensive option I'm not ready for now. I wouldn't mind dropping it down to a 2.5" lift though if I could get by without spending a bunch of money to do it. Guessing it would require different front leaf springs and a shorter block in the back? I should still be able to use the 33's with the smaller lift?
02-07-2018, 11:46 AM | #31 | |
Re: New to squares
You could get BDS front springs or Tuff Country. Then new blocks in back and new Axle Ubolts. The only question would be the shocks that are mounted. Some can handle a little bit of drop, but you'd have to check out the model numbers to see if it could handle the lower ride height. Here is mine with a 2.5" lift and 33" tires.
02-07-2018, 11:48 AM | #32 |
Re: New to squares
And just for fun when I first bought it....
37" tires on 2.5" lift. Yea, didn't last too long after I bought it!
02-07-2018, 12:31 PM | #33 |
Re: New to squares
One no added cost thing you can do to keep the transmission from hunting between overdrive and direct drive at 80 mph is to manually select 3rd gear on the column shift. This would keep the engine in the max power band, possibly increase fuel economy and prolong the life of your transmission.
02-07-2018, 03:12 PM | #34 |
I know the pieces fit
Re: New to squares
Lowering the truck to a 2.5" lift "should" help, right? You're getting the truck a little bit closer to the tires and hopefully it'd help with wind drag under the truck. But I wouldn't install a 2.5" lift unless that's the lift you really want because I don't think it's going to fix the problem you asked about.
Like everyone else mentioned, the truck has the aerodynamics of a billboard and the TBI 350 wasn't a powerhouse. The truck's already been regeared properly for the tires, the only sure fix now is horsepower, or more accurately, torque. I don't mean to be a killjoy because I love your truck and I'd DD it but if it were me I'd leave 15 minutes earlier every day, slow it down to 72 or 73, and enjoy driving a badass truck. |
02-07-2018, 03:18 PM | #35 |
Re: New to squares
^^ Agree 100%.
02-08-2018, 09:18 AM | #36 |
Re: New to squares
Since your transmission is hunting between 3rd and overdrive at 80 mph, just manually shift it in into 3rd. You'll at least prolong the life of the transmission. I calculated the RPMs.
2343 RPM, O/D @ 80 mph 3437 RPM, 3rd @ 80 mph The 350 develops more power at 3437 RPM than 2343 RPM and your 350 engine should be happy running at 3500 RPM. |
02-08-2018, 10:40 AM | #37 | |
Re: New to squares
I'll see what I can do with giving myself more time, but I'm usually in a rush after work to get 1 or more of the kids on to their activities. |
02-10-2018, 08:45 PM | #38 | |
Re: New to squares
try the lower height and smaller tires . Do not give up and sell it . It history and deserves to be saved . and keep out of snow ?
88 Suburban Silverado (original 48,000mi) 99 GMC Z71 stepside 01 GMC 2500HD crew (Texas truck) 07 Chevrolet Suburban LT 84 Chevrolet S10 short box 355 V8 |
04-10-2018, 10:08 PM | #39 |
Re: New to squares
Someone stole my suburban today while I was at work! We have a private parking lot and they still smashed the window and it's gone! Just some broken glass is all I found when I went out after work.
If anyone sees it please let me know. |
04-10-2018, 10:27 PM | #40 |
Re: New to squares
Damn, that really sucks. I always worry when I park mine in a place I'm not familiar with. I really need to install a kill switch.
04-11-2018, 04:08 PM | #42 |
Re: New to squares
I can't believe it!! So sorry!
Keep my eyes open for it....
04-11-2018, 06:22 PM | #43 |
Re: New to squares
Man, that's bad news.
Romans 10:9 - The Truth |
