Old 12-29-2008, 04:00 AM   #1
Chris in Idaho
TBI Straight 6
I'm planning to make adapter plates to put TBI on 6 cylinder intake manifolds, I'm wondering which manifold people would like to use. I can make it for the Monojet, which would probably work great, but I think the Varajet might work better. What do you guys think?
Here's a pic of the adapter I make for Jeep 6cyls:
Chris in Idaho is offline   Reply With Quote
Old 12-30-2008, 12:27 AM   #2
bucket
bucket's Avatar
Re: TBI Straight 6
here is a recent link over at stovebolt: http://www.stovebolt.com/ubbthreads/...401#Post487401
79 K10
77 MGB
79 Kawasaki KZ1000
bucket is offline   Reply With Quote
Old 12-30-2008, 01:07 PM   #3
Chris in Idaho
Re: TBI Straight 6
Thanks. I hadn't seen that forum before, looks like another good source of info.
Old 12-31-2008, 10:42 AM   #4
D13
D13's Avatar
Re: TBI Straight 6
I'm looking to do this conversion eventually (too many projects in front of it LOL). My issue with the 2bbl set up is that it only came on the integral head. Where I was headed was a Clifford 4bbl water heated intake with a custom adaptor. Then I could use one of my other heads. The Monojet intake looked to need a bunch of machining to get rid of the shape mismatch of 1bbl to essentially 2bbl.
Let us know what you end up doing. Some of us might be interested in buying a couple of copies for our own projects!
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-01-2009, 12:00 AM   #5
Chris in Idaho
Re: TBI Straight 6
I didn't realize the varajet was only on the later engine with the integrated intake head. Yuck. I think I'll machine up an adapter to put TBI on a monojet intake. I know it seems silly to choke a 2bbl TBI down to 1bbl, but if you're just looking for the benefits of TBI this would be an easy way and it will still flow better than the 1bbl carb did.
Old 01-03-2009, 01:58 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: TBI Straight 6
I would go with the TBI myself. You can already do such with a 4bbl intake with a TBI adapter. A TBI setup for a 4.3L would be a good setup on a 4.1 I6.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-04-2009, 01:48 PM   #7
sierra4x4
sierra4x4's Avatar
Re: TBI Straight 6
I am about to start a TBI conversion on a 1970 250 that i put in a 85 chevy k2500. I took all the TBI setup off a 1990 chevy 1500 305. I am going to use a stock 250 HEI dist. and a Tbi ignition module. does anyone have any pictures of a TB to monojet manifold adapter plate?
sierra4x4 is offline   Reply With Quote
Old 01-05-2009, 07:37 AM   #8
D13
D13's Avatar
Re: TBI Straight 6
No, but I would be very interested in your ignition set-up. Howell sells one for this conversion for $250, but I'd like to see someone do a low buck version using factory parts.
1987 2 ton
Old 01-05-2009, 10:52 PM   #9
sierra4x4
sierra4x4's Avatar
Re: TBI Straight 6
D13, The ignition set-up is very easy, all i am doing is gutting a stock 250 HEI dist. (removing the advance spings, weights and module) then tack weld the top so nothing moves(eliminating the mech adv.) after that just run the 2 wires from the pick-up coil to a stock GM TBI ignition module so all timing is computor controlled. don't forget to unhook the vac adv.
Here are a few images on non GM TBI dist conversions but same concept.
Old 01-06-2009, 07:47 AM   #10
D13
D13's Avatar
Re: TBI Straight 6
So essentially you've converted to a 7 pin module outside the distributor, resued the stock HEI pick-up and locked the distributor timing, right?
Hmm, i was going to do some machine work to mate a 4.3 distributor to the 250 lower section, Your way looks a lot easier.
The poor fit of the 2bbl TB to the Monojust was why I was looking to go Clifford, use a water heated manifold (help the fuel atomization here in MI) and then make a very simple mounting plate to bolt on their 4bbl base (I actually think someone sells this, but it's not very hard to make one with 1/4" alum plate, drill, and sanding roll).
I'd also get the better fuel distribution of the Clifford manifold.
1987 2 ton
Old 12-11-2012, 02:50 PM   #11
67stepsideC10
67stepsideC10's Avatar
Re: TBI Straight 6
You guys made any progress on this in the past few years?
CURRENT: '64 Stepside C10 Rat, 250ci Inline 6, 3 spd on Column (Thread)
PAST: '67 C10 Stepside, '79 Sierra
67stepsideC10 is offline   Reply With Quote
