Old 06-11-2005, 01:28 PM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
Safety vs Original - Brakes and Roll bars
-Currently I am running the original front drum setup on my 69. Seem to work good. Many people have changed to the disk setup, but are the drums really that unsafe? I really want to keep the factory setup, but don't want brake failure either!
-Also, I really enjoy the look of the classic blazer (69) as it came without the rollbar. I also know this is not the safest if a rollover occured. But I only use for street driving so what are the chances. Thoughts?
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 06-11-2005, 01:47 PM   #2
jhow66
jhow66's Avatar
Drums brakes are no more unsafe then disc. Just that disc have more stopping power.
Rollbar-how many cars with the top down have you seen with a rollbar?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-11-2005, 01:48 PM   #3
Medicanman71
Medicanman71's Avatar
Why is it not the safest in a roll over? Because a 6 or 8 point bar is stronger? Ok i agree.... But as far as 4 point bars go..... i'm not understanding?
The only time they wouldnt be safe is if they're not installed correctly....
- which is probably most of the time.
Out of all those of you who have roll bars.... how many have backing plates under the tub? (under the wheel wells and up front where the bolts poke through.)
If you just use a nut and washer there ( like most!) then yes - when and if you roll - the roll bar will TEAR right out.... If you use backing plates so the nuts and washers cant pull through.... then i'd imagine you're doing OK. This is my case.... as i dont do any major wheeling... but i love cruising the fire roads around here and like all the CDF trucks - i got my roll bar too.
Seat belts is another story
Medicanman71 is offline   Reply With Quote
Old 06-11-2005, 06:23 PM   #4
71jimmy
71jimmy's Avatar
Agree with Jhow66.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 06-11-2005, 08:48 PM   #5
vtblazer
vtblazer's Avatar
I think he's saying, his doesn't have a roll bar at all.
I agree with ya jakeslim, I like the looks without also.
I have mine installed because of my kids.
vtblazer is offline   Reply With Quote
Old 06-12-2005, 03:22 AM   #6
69TowRig
I'm still trying to finish the power disc brake conversion (from manual drums) on my '69, but since the goal is to tow with the truck it is necessary. I can't afford to have crappy brakes towing either my boat or my trail rig hooked to the rear of the Blazer.
I will be adding a rollbar to mine as well, I want to also take it to the beach a time or two and run around on the nicer weekends without a top on. If it's done right it will look clean and factory. Same with the brakes. Only a die-hard fan would know that the stuff was not original. Make the truck meet YOUR needs.
69TowRig is offline   Reply With Quote
Old 06-12-2005, 08:27 AM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
My $.02 for whatever it is worth
2WD - Blazers and Jimmy's - NO BAR
4WD - Blazers and Jimmy's -
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
