02-27-2023, 03:18 PM | #1 |
I need a hood picture if you have one that's off a truck
When I removed my hood from the hinges on my 67 I saw that the rear nuts closest to the cowl were starting to pull thru the metal and the metal is all deformed. Could someone take a closer picture of that area so I can see what it is supposed to look like ? The front ones appear to be good.Thanks in advance.
02-28-2023, 04:02 PM | #2 |
Re: I need a hood picture if you have one that's off a truck
These pictures are of a hood off of a 72. I’m not certain if 72 and a 67 are the same in the area where the hinges bolt on. I would think that they are.
Perhaps a member that knows for certain can confirm Hopefully this helps in some way
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
02-28-2023, 05:13 PM | #3 |
68 C10 Longbed
https://www.67-72chevytrucks.com/vbo...1&d=1677618736
Here’s the my hood 68 |
02-28-2023, 05:17 PM | #4 |
68 C10 Longbed
Sorry just can’t figure the pics out. Last edited by ghackett1; 02-28-2023 at 05:22 PM. |
02-28-2023, 05:18 PM | #5 |
68 C10 Longbed
02-28-2023, 08:33 PM | #6 |
Thanks. The hinges are the same so I would assume that the stamp would be as well. I just wanted to make sure I was straightening something that wasn't supposed to be. Much appreciated
02-28-2023, 09:02 PM | #7 |
68 C10 Longbed
