08-17-2017, 10:05 AM | #26 | ||
Re: Accuair problems
I would like to switch to an automated system on my current build (couldn't afford it while building the dually & don't have the desire to pull it apart just for the automation). But, I don't want to deal w/unnecessary electrical issues because of it. Why is there always a draw?
08-17-2017, 12:50 PM | #27 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-18-2017, 01:54 AM | #28 |
There are some great questions and great comments in this thread (BigMike and his Chia Pet example is my favorite).
- The e-Level system currently pulls 0.038 amps when the ignition is OFF (assuming the orange wire is actually wired properly to ignition). This current is required because we chose to leave the processor on all the time in order for the key-fob remotes to always work. This may evolve to shutting off after 24-48 hours in the future to get the current down to 0.002 amps or less. - 0.038 amps is not enough to kill a good battery over any reasonable amount of time (months). But, when you have air compressor(s) that pull 26 amps a piece, keeping a good battery is hard to do. You can think of running your dual compressors like cranking your starter. Once you run your compressor(s) for a while without the engine running (not a great idea) your battery is going to be depleted. Alternators don't always top-off the battery charge especially at idle. - When parking your truck for an extended period (even a week) the best thing for your batteries is to plug into a battery tender (40 bucks at any auto parts store). This will top-off your batteries from the compressor abuse and help them last as long as possible. - In the early 2000s gel cell batteries were awesome. You could beat them up (draw them down to 9 volts or less), then charge them back to normal and they would hold it. This is no longer the case with the gel cells we have used. These days we use conventional lead acid batteries that have a good warranty and seem to get the best results. A few of you have hit the nail on the head about air suspension in general. If you buy crappy product, then you are going to get crappy results. If you buy a great product and install it like crap you will still get crappy results. Me and my guys go to the end of the earth to help people through their installation mistakes. Unfortunately, the common attitude when people are having a problem is "your product is broken". Its best to keep in mind that we 100% test 100% of the product that we ship out the door (a rare investment in this industry). Its also good to remember that we have over 30,000 e-Level systems on the road at this point (thanks to many of you guys). No product is perfect and sxxt happens, but spend the time to do a good install, be patient if you are having a problem, and then enjoy the benefits. Cheers |
08-18-2017, 09:18 AM | #29 | |
08-18-2017, 09:52 AM | #30 |
It's an option and it can be unplugged if you like. I'm going to try that on mine and see what difference it makes. I normally try to keep mine on a battery tender just to make sure I have no battery issues.
08-18-2017, 01:02 PM | #31 | |
Again, 0.038 amps is not a large "drain", it is a very very small one. But, if having any drain doesn't work with your philosophy then you can always put a simple kill-switch in the main power wire to the ECU. The system won't loose its memory or anything like that, so we have had a handful of people choose to add a little toggle switch under the dash. |
08-18-2017, 01:51 PM | #32 |
Reno, I am about to install my E-level setup on my Blazer. Could I just run the power wire to a "Key-On" source, so that I don't have to remember to flip a toggle switch?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
08-18-2017, 02:03 PM | #33 |
You would need to use a relay because the e-Level system pulls a maximum of 15 amps through the main power wire (i.e. the relay coil would get triggered on by your ignition 12V, the relay source would be the battery, and the relay output would be the e-Level power wire).
08-18-2017, 06:18 PM | #34 | |
08-18-2017, 07:37 PM | #35 | |
08-19-2017, 10:45 AM | #36 | |
