Old 07-17-2016, 10:00 PM   #1
ghalperin
ghalperin's Avatar
67 Plain Jane C10 396 3 on the tree
Two weeks ago I picked a very original 67 step side.
Check my post in the Introduction Section for details.
http://67-72chevytrucks.com/vboard/s...d.php?t=711786
I've had good luck finding original parts to put it back to stock. The engine appears to be a replacement. I was told that the engine has less than 20,000 miles on it. It does run very well. The coolant is nonexistent and the red rusty crap in the radiator was starting to weep from the head gasket. My plan was to replace the head gasket and run it. On my way home from the parts store with the head gasket set, a freeze plug blew out behind the bellhousing.
So, I had a decision to make. Pull the engine and trans and reseal them. Or, put a different engine back in. Since it's not the original engine, I've decided to replace it with something else. I like the basic bare bones idea of the 3 on the tree, although I'm not a fan of no OD.
So I couldn't go with a 350 like every other hot rod, so I looked for either a 327 or a 396. My goal was to find a period correct stock looking engine. Last week I drove to Pismo Beach chasing a big block, but came home empty handed.
I wasn't having any luck finding an appropriate 327 and then I ran across a Craigslist ad for a 68 396, pulled from a 68 C10.
I bought that engine. 68 Hipo block 396 with 67 427 heads. It wasn't the complete engine that I was looking for, but it comes from a good source with a known history. It does have a RV cam, stock exhaust manifolds and a factory Holley manifold. I picked up a set of Big block stands.
I do plan on stock wheels with COPO caps, disc fronts and lowering.
Now I have some parts to find:
Single belt water pump pulley
Flywheel
Clutch kit
V8 transmission cross member
V8 column shift linkage
Overdrive cable and t-handle
ghalperin is offline   Reply With Quote
Old 07-18-2016, 12:05 AM   #2
ghalperin
ghalperin's Avatar
Re: 67 Plain Jane C10 396 build
Here's my 396:
Old 07-18-2016, 12:16 AM   #3
68bowtie
68bowtie's Avatar
subscribed! i like the plan. how low are you going to go? i assume you're going to keep the wheels/tires that you have on there...
i have a set of bbc alt brackets on my "random and miscellaneous" sale thread. i'm told they are for a lwp but i'm not positive. i pulled them from a 396 with a bunch of top end parts from a mid 70's big block.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 07-18-2016, 01:24 AM   #4
ghalperin
ghalperin's Avatar
Thanks for the offer on the brackets, but I'm looking for this style:
I plan on making my engine look just like that.
I plan on 2 1/2 spindles with either 1 or 2 inch springs on the front and somthing similar in the rear. I'm staying with the 15 inch steel wheels, but I may go a little wider to 7.
Old 07-18-2016, 03:21 AM   #5
ghalperin
ghalperin's Avatar
Dazza Photoshopped the COPO caps, yellow wheels and lowered height:
Old 07-23-2016, 05:38 PM   #6
ghalperin
ghalperin's Avatar
I've been busy buying parts:
ECE front disc with 2 1/2" drop spindles
ECE 2" drop front springs
Holley 750 vacuum secondary carb
Saginaw 3 speed with Overdrive
COPO poverty hub caps
Please send me a PM if you have anything on my want from the first post.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
Old 07-24-2016, 08:22 AM   #7
Maddoxdb
Maddoxdb's Avatar
Sub'd.... I'm really diggin this truck! Plus I need some motivation to work on my 67!! Later, Dustin
Maddoxdb is offline   Reply With Quote
Old 07-24-2016, 10:19 AM   #8
6t9camaro
6t9camaro's Avatar
I like it!!!
6t9camaro is offline   Reply With Quote
Old 07-25-2016, 12:06 AM   #9
Mapearso
Nice truck! Was this out of AZ? Saw something very similar a couple weeks ago that went quick!!!
1972 C10 SWB Cheyenne Super 350/350
http://67-72chevytrucks.com/vboard/s...d.php?t=691825
1972 C10 SWB 454/400 Cheyenne Super Project
http://67-72chevytrucks.com/vboard/s...t=Project+KISS
Mapearso is offline   Reply With Quote
Old 07-25-2016, 12:36 AM   #10
ghalperin
ghalperin's Avatar
That's the one, Craigslist Scottsdale.
It was a weird purchase. I almost thought it was a scam. No phone calls, no negotiation, no deposit, cash on pick up only. The listing got flagged, but I had already started communicating via email. I was lucky that I had a friend that lives close by, he went immediately and bought it for me. I actually had it shipped to me overnight and had it the following day.
Glenn
Old 07-25-2016, 12:39 AM   #11
ghalperin
ghalperin's Avatar
Yesterday I found my clutch linkage, due to a WTB ad here in the parts section.
Today I picked up a complete original engine. It's a never opened 1969 396 out of a C30 Longhorn.
Glenn
Old 07-25-2016, 01:03 AM   #12
68bowtie
68bowtie's Avatar
Today I picked up a complete original engine. It's a never opened 1969 396 out of a C30.
looks like that one's got all the parts you need! are you going to drop it in or rebuild it?
Old 07-25-2016, 03:20 PM   #13
tommys72
tommys72's Avatar
Coming up with all kinds of good parts quick for this one
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-14-2016, 09:29 PM   #14
ghalperin
ghalperin's Avatar
Question Re: 67 Plain Jane C10 396 build
I just got back from vacation to find a few parts on the porch. I now have most of my clutch and shift linkage. I also picked up an OE gas pedal.
Does anybody know if I can use the I6 bellhousing, flywheel, clutch and starter?
Glenn
Old 09-07-2016, 06:38 PM   #15
ghalperin
ghalperin's Avatar
I'm still collecting parts. CPP has this kit floating in the bay. 5 inch springs. 1 1/2 inch blocks. The price was pretty good ($380 shipped) and as part of the deal, they threw in the spring retainers when I picked it up.
Name:  rear drop kit.jpg
Glenn
Old 09-07-2016, 06:58 PM   #16
ghalperin
ghalperin's Avatar
Since it's never been apart, I'll have the heads redone with hardened valve seats, before I drop it in. It's supposed to have about 50K miles, so I doubt if it needs more work.
Glenn
Old 09-10-2016, 12:54 AM   #17
randy500
Yes you should be able to use all those parts. Unless the I6 was a 292, that might be external balance, don't know about the balance on those, but if 250 I6 all that will work. You do need a V8 bellhousing crossmember though, it sits forward of where the I6 one does and is a different bend, there is a thread here explaining the difference.
I like your truck and love the 396 all stock look concept, very cool. Very nice looking longhorn 396 you acquired too!
I have the V8 crossmember if you need it still.
randy500 is offline   Reply With Quote
Old 09-10-2016, 12:57 AM   #18
randy500
One more thought, I believe you now have a 1-piece driveshaft and you will need a longer one when you install the V8 crossmember, I think even in 68 that combo used a 2-piece driveshaft as the later models ones do.
Old 09-10-2016, 02:07 AM   #19
ghalperin
ghalperin's Avatar
Thanks for the input and offer on the crossmember, but I did pick up a V8 crossmember. The engine in it is a 250, so I'm stoked to be able to reuse all those parts. I also picked up an original 4 core radiator (that was rebuilt to 5 core and came from the same Longhorn) along with the shroud. Now I'm trying to locate the 3/8 fuel line with sending unit and the big block throttle linkage. My parts list is getting pretty short.
Glenn
Old 09-10-2016, 02:15 AM   #20
ghalperin
ghalperin's Avatar
I do have a one piece drive shaft. I know that moving the engine forward would require the drive shaft to be lengthened, but adding the overdrive would require the drive shaft to be shortened. Those two mods may cancel out any drive shaft mods, but I'll tackle that one after the 396 and OD are installed.
Glenn
Old 09-21-2016, 01:47 PM   #21
ghalperin
ghalperin's Avatar
I picked up my overdrive lockout cable.
Glenn
Old 10-05-2016, 12:15 PM   #22
ghalperin
ghalperin's Avatar
My shopping list is getting pretty short. I just picked up an original matching rear sport bumper with brackets.
Glenn
Old 10-07-2016, 01:29 PM   #23
ghalperin
ghalperin's Avatar
I installed the rear bumper. It looks so much better than the old step bumper and it's about 40 lbs lighter.
FYI - that old step bumper weighs 80 lbs. Good ridance.
Glenn
Old 10-07-2016, 02:00 PM   #24
68bowtie
68bowtie's Avatar
bumpers make such a huge difference in appearance. it's a match made in heaven in my opinion. very nice...
still liking those chromed caps over the factory white caps?
Old 10-07-2016, 02:41 PM   #25
ghalperin
ghalperin's Avatar
Personally, I like the contrast the caps give to the white wheels.
White caps would blend in too much.
Glenn
