11-19-2010, 09:43 AM | #1 |
Slots go on anything!
need gauge cluster wiring diagrams
I am getting ready to Frankenstein a tach cluster for my '74, and need to see if anyone has a diagram of the gauge cluster for a '74 and 76-77. I am going to put a voltage gauge in my '73-4 tach cluster, and repin the plug. Just need to see what is where. I think I have a '77 cluster in there already, it has a voltage gauge and mechanical oil pressure. I am almost sure it is the one out of my old '77 Blazer, but don't remember for sure. Thanks in advance, if anyone has them....
1974 Jimmy- 5.3/4L80e/NP241 |
11-19-2010, 09:09 PM | #2 | |
Re: need gauge cluster wiring diagrams
I don't care for ampmeters & like to know the voltage. I removed the amp gauge & removed the amp gauge circuit board tabs. I installed the voltmeter out of that 77 cluster, wired the 12v source to the pwr feed for the clock (since it no longer worked) & ran a short ground to the cab under the dash.
11-19-2010, 11:31 PM | #3 |
Problem solved. I guess I should have asked the Man. Now it's obvious I am too lazy to unscrew the last 3 screws to get the cluster out.... I guess it didn't register that the voltage gauge was in there until last weekend. I went to pick up furnature and started mapping out my tach swap and noticed it then.
