Old 08-08-2017, 09:38 AM   #326
scoot_mcgrute
Re: 1966 C10 Project Truck
Originally Posted by doublebeetx View Post
I started this process recently also. Something I did notice when drilling spot welds on the inside of the panel, the outside panel isn't cut flush with the inside panel. I haven't put a ruler on it yet , but I'd guess it's 1/8 to 3/16 difference in some areas. I'm going to make a pattern of mine before I take it apart to make sure and transfer the opening to my truck so the glass fits right. I read something not long ago about a guy who cut his out and his glass was "loose" as he described it. That makes me wonder if it the outer panel needs that little extra length.
That's great information, thanks for sharing. My original plan was to use the inner panel as the template but maybe the best way to go about it is to make a template of the outer panel. I have some layer board I can steal from work so I will most likely use the outer panel for the template when I get to my conversion.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-21-2017, 01:45 PM   #327
scoot_mcgrute
Hit up another autocross yesterday, I'm very happy with how it does out there. I do have a list of things to fix this winter and maybe before then. I need a bigger sway bar and/or stiffer springs up front, the open diff is killing me, the steering isn't up to snuff, the bench seat is less than ideal and my anti-squat is all jacked up so I can't really put any power down in the corners. I'm going to see if I can swing a new front sway bar before the next event in September but the rest will come later.
My second lap, I decided to see what the threshold was for the crossover. Carried too much speed and well you'll see
https://www.youtube.com/watch?v=HWeNC8rFHX8
My best and last lap, ran a 42.815 which for the bumpy course, I was stoked to hit!
https://www.youtube.com/watch?v=0UmdmEzzpEY
1966 Army Truck
Old 08-28-2017, 05:07 PM   #328
scoot_mcgrute
Couple pictures from the last autocross. I'll be doing quite the teardown this winter to address a few things, the smoke from the tailpipe is top of the list. I'm hoping it's something easy...
This is from my spin, love how the picture turned out
Smokey
1966 Army Truck
Old 09-25-2017, 10:04 AM   #329
scoot_mcgrute
Beat on the old girl pretty hard over the weekend with two autocross events, this thing is so much fun! I'm starting the winter upgrade list to get it to handle better and get it more competitive on the autocross course with the teardown coming soon. First thing will be to buy the Porterbuilt adjustable trailing arm crossmember so I can get proper traction to the rear tires and then a lot of little things to help the front suspension out.
Fastest test and tune lap
https://www.youtube.com/watch?v=Lylr5cBSBH0
Fastest autocross lap
https://www.youtube.com/watch?v=wuNJmnnYO08
Instructor lap
https://www.youtube.com/watch?v=WM-TOka5jlw
1966 Army Truck
Old 10-01-2017, 10:57 AM   #330
SKT
SKT's Avatar
Can't believe I missed this thread!
Wow, what a SHARP looking truck - job well done w/ this build!
SKT is offline   Reply With Quote
Old 10-01-2017, 11:21 AM   #331
Bomp
Really?
Bomp's Avatar
Killer build in the making.
the_bompenstein on instagram
Bomp Fb Truck page
Bomp is offline   Reply With Quote
Old 10-02-2017, 10:01 AM   #332
scoot_mcgrute
Thank you, I appreciate the kind words!
Thanks Mr. Bomp!
I ordered the Porterbuilt crossmember last week, just waiting for them to build it and ship it. I'm estimating just a couple more chances to drive it this year so the teardown will happen fairly soon. There's another autocross on the 15th but the weather doesn't look promising so I'm guessing that I'm done for the season.
On the docket for this Winter:
99-04 Mustang 8.8 rear axle
Rear panhard bar
New rack and pinion - maybe
Caster correction
Camber correction
Front and rear shock relocation
Rear C-Notch
Big back window
Cab rust repair
Check back in for some build updates in the coming weeks
1966 Army Truck
Old 10-05-2017, 12:38 AM   #333
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
Old 10-05-2017, 04:30 PM   #334
shearjs
shearjs's Avatar
Great build! I've read through all of Hackster's builds which lead me to follow yours. Both of you guys are giving me the inspiration I need to tear into my 54 F100 this winter and get started. Looking forward to seeing your upgrades and progress!
shearjs is offline   Reply With Quote
Old 10-06-2017, 10:09 AM   #335
scoot_mcgrute
I'm honored to have you watching and following along, Hackster does some great work and it's finally rubbing off on me. He has been a large part of what the Army Truck is and always willing to lend a hand when I need it, good dude for sure
1966 Army Truck
Old 10-07-2017, 09:41 AM   #336
rusty76
rusty76's Avatar
Just spent some time going through your build. Really cool truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-09-2017, 10:55 PM   #337
Mack B
Mack B's Avatar
I just found this, and went back and read it all. I like what you are doing here, Great build!
Mack B is offline   Reply With Quote
Old 10-17-2017, 01:46 PM   #338
scdude37
New member here, and I love this write up. Very impressed and jealous. Just bought my first project 1965 c10 lwb. this gives me a lot of inspiration. Cant wait to follow this build through the winter with all the ideas you have to improve it.
scdude37 is offline   Reply With Quote
Old 10-18-2017, 09:51 AM   #339
scoot_mcgrute
Thanks for the kind words, everyone!
I got my Porterbuilt trailing arm crossmember the other night and my excitement level immediately went to a head scratching fest. The reason why I went with theirs is because of the fine adjustment in anti-squat, I actually have a model drawn up that looks identical to theirs, and when I pulled it out of the box there were only 3 holes. Not what I want. I'm going to decide whether it's worth cutting their brackets off and doing my own or send it back and start from scratch.
Their website picture, notice the "scalloped" hole design with a lot of adjustability
And what I got
They changed the design about 6 months ago and haven't updated the website yet if anyone is curious.
1966 Army Truck
Old 10-23-2017, 02:00 AM   #340
CruizinKev
Thumbs up Re: 1966 C10 Project Truck
Love this build! btw sent you PM
CruizinKev is offline   Reply With Quote
Old 10-28-2017, 06:01 PM   #341
scoot_mcgrute
Picked up a new axle for it today, it's an 8.8 out of a 99 Mustang GT with a limited slip, disc brakes and a 3.30ish gear ratio. Should compliment the motor quite well!
1966 Army Truck
Old 10-29-2017, 01:19 AM   #342
Captainfab
60-66 Nut
I'm curious as to what the width is of that 8.8........
Old 10-30-2017, 10:21 AM   #343
scoot_mcgrute
62.5 wheel mount to wheel mount. Can't get a whole lot closer to what our 12 bolts are
Got it on the dyno yesterday at a local Subaru shop open house and dyno day. Didn't throw down the numbers I was thinking it would but their dyno is very stingy on the power numbers. It put down 234/261 which is not horrible, I just loved seeing it on the dyno!
4th gear pull, took a little long to get going
https://youtu.be/e6TCPwesH5Y
3rd gear pull, he stabbed it a little hard and spun
https://youtu.be/GtGHxZRWfg4
3rd gear pull, tighter straps and ballast
https://youtu.be/GyNwb00aBTo
1966 Army Truck
Old 10-31-2017, 02:13 PM   #344
aggie91
I'm just glad to be here!
aggie91's Avatar
One more question about the Mustang 8.8. Is the pinion centered? I know that on an Explorer 8.8 it is offset to the passenger side.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-31-2017, 04:57 PM   #345
scoot_mcgrute
I believe it is, I know the shafts are the same length but I will confirm if it's centered tonight.
1966 Army Truck
Old 11-02-2017, 09:51 AM   #346
scoot_mcgrute
It looks to be centered up, if not it's like 1/2" off side to side.
1966 Army Truck
Old 11-02-2017, 11:28 AM   #347
aggie91
aggie91's Avatar
Thanks, I used a 8.8 from an explorer, it is something like 59.5" wide at the WMS, but the pinion is offset to the passenger side like 1.5"-2". It works for now, but I might have to look for a mustang unit...
Karl
The LST Challenge:
Old 11-06-2017, 04:01 PM   #348
scoot_mcgrute
I spent the weekend helping my buddy get his new shop setup, we hung some cabinets and built a huge workbench. They're moving about 2 hours away so I won't be able to bug them all the time but they're still somewhat close by. When I got home, I had some more truck parts waiting for me. I got the Performance Online axle swap kit, well built and comes with what you need to put a different axle under your truck. Can't wait to start working on things again!
1966 Army Truck
Old 11-07-2017, 12:27 AM   #349
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice!
Is the bar adjustable?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 Service truck build:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-07-2017, 10:52 AM   #350
scoot_mcgrute
Originally Posted by LostMy65 View Post
Nice!
Yep, it's adjustable on both ends which nets 4" of adjustability. It'll be way nicer to get things centered up with the adjustments on both ends because you can loosen the jam nuts, spin the bar and then tighten the nuts back up when you're done.
1966 Army Truck
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
