Old 12-02-2017, 10:43 PM   #1
Bentbolt
73-87 control arms and crossmember
I have a 65 c20 I’m planning on switching to 73-87 c10. I bought a rolling chassis 86 to use as donor. Bottom arms was already cupped. But I found the spring buckets in the cross member are full of rust and holes. The 65 c20 is rust free. Would the 86 upper and lower arms fit the 65 crossmember?
Bentbolt is offline   Reply With Quote
Old 12-04-2017, 10:54 AM   #2
Pro Performance
Pro Performance's Avatar
Re: 73-87 control arms and crossmember
Yes, they should bolt right onto the 65 frame. The 73-87 use difference bushings, but if you take the complete assembly with cross shafts, you should be good to go.
Pro Performance is offline   Reply With Quote
Old 12-04-2017, 11:09 AM   #3
Bentbolt
thanks yes, I still have the cross shafts for the 73-87 a arms. I plan on using all new bushings and steering components. I was just un sure the arms would bolt up to the cross member
Old 12-04-2017, 11:17 AM   #4
Pro Performance
We have a conversion tie-rod to use the later 73-87 spindle with your earlier 63-70 inner tie-rods and steering components.
http://www.azproperformance.com/Alum...71-87-C10.html
Old 12-04-2017, 02:24 PM   #5
Bentbolt
sounds good. im gonna put the steering box of the 86 over on the 65 and replace all the steering. I will be calling soon to place a order
Old 12-10-2017, 01:39 AM   #6
dec010974
dec010974's Avatar
Just to get a better understanding, I have a 1972, Chevy C10. If I bought 1
1973-1987 Control arms, Spindles, Rotors, calipers, inner/outer tie rods, etc, to use with the 1972 c10 center link, this would work, right?
dec010974 is offline   Reply With Quote
Old 12-11-2017, 05:58 PM   #7
Pro Performance
You can use all 73-87 parts with your centerlink, but must keep the inner tire rods, then just change the outer to 73-87. The thread is the same (11/16) on 71-72 and 73-87 outers. No need to change inners, plus they match the center link where the 73-87 wont.
Old 12-12-2017, 08:45 PM   #8
CC69Rat
CC69Rat's Avatar
Bolts right up ! My 68 has the 73-87 swap, it's not difficult at all. You have to drill two holes but that's it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
