Old 07-19-2014, 01:54 PM   #1
WhiteWhale
WhiteWhale's Avatar
Anyone have pics of 9.00 r16 on their 4x4?
Saw some 9r16 super tractions and wondered how they look on 72 and earlier trucks or suburbans.
I think thats what they are running on the truck in the promotional video but would like to see them on something later.
https://www.youtube.com/watch?v=x5LYTkRjdno
WhiteWhale is offline   Reply With Quote
Old 07-23-2014, 08:15 AM   #2
Re: Anyone have pics of 9.00 r16 on their 4x4?
I don't see 9.00s around any more,but I got 255/85-16s to get pretty much the same dimensions...in a radial. The first picture is a set of all seasons I ran years ago on my '92 K3500. I put them on again last fall (Cooper Discoverer S/Ts),then they went onto my non-lifted '72 K2500 this spring. Me and some buddies used to run 9.00s in the late-70s and that's what I've come back around to
Old 07-23-2014, 08:22 AM   #3
And here are some stand-alone pictures. These are mounted on Ford 7" wheels. The other tires are 33/12.50-15s mounted on 10" wheels for comparison:
Old 07-23-2014, 11:49 AM   #4
WhiteWhale
WhiteWhale's Avatar
Those look great!! How did they clear on the 72 with no lift? I see in the GM literature there was a 9.5 16.5 offered, that size I cannot find.
These are still available so though someone might have run them
http://simpletire.com/jetzon-9.0016l...FQmoaQod8j8A2w
Old 07-23-2014, 12:35 PM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
I've ran the old Power King 9.00 x16s on several trucks and even a Blazer, I really like them. The farmers and ranchers around here used them on there 1 tons cause they got around so good....as long as your going forward! They don't do well in reverse. Make sure whoever mounts them knows they are a directional tire, and I never did run tubes in them and never had any trouble.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 07-23-2014, 12:40 PM   #6
BLAZERMAN
BLAZERMAN's Avatar
I had a Detroit locker in the rear and a Trac-Loc in the font of that old 1 ton Stepside with 4.56 gears... It was unstoppable in deep mud or snow.... But really kinda scary on hard packed snow or ice.
Old 07-23-2014, 12:57 PM   #7
WhiteWhale
WhiteWhale's Avatar
BEAUTIFUL!!
No ice or snow here in SoCal so little worries. How tall did they actually measure? The site says 34 inches.
Did you have a lift on the truck?
Old 07-23-2014, 12:59 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Anyone have pics of 9.00 r16 on their 4x4?
Great comparison pics. If I ever wear out my 33/12.50-16.5s (not likely at the rate I'm going), my best replacement choice is what you have: 255/85-16s, probably on Ford 7" wheels. Same height but narrower. Nice.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-23-2014, 01:10 PM   #9
BLAZERMAN
BLAZERMAN's Avatar
Originally Posted by WhiteWhale View Post
BEAUTIFUL!!
Yep they measure a true 34", I had a 4" lift on that truck and the Dana 60 front added almost another inch.
Old 07-23-2014, 09:30 PM   #10
1972RedNeck
1972RedNeck's Avatar
9.00R16's (Michelin makes them for the military) cross over to a 255/100R16 - taller than a 255/85 by a full two inches.
The tire I would love to run is Michelin's 8.25R16 or 235/100R16. The only problem is, they are only available in europe.
THIS PLACE has a tubeless 9.00x16 that is 14 ply. I kind of want to try a set but I don't have any chains to fit them.
1972RedNeck is offline   Reply With Quote
Old 07-24-2014, 08:21 AM   #11
Those tires look like the Power Kings and Regul Trailblazers. I think they are all the same tire under different names. Universal Tire,a vintage tire co. like Coker, had a set of Trailblazers on display at an antique truck show I was at last year.
The 9.50-16.5s are a shorter wider tire,basically a wide oval profile...a whole different profile. I offered up the 255/85s because your title indicates you're looking for radials and I don't know of any 9.00 radials ever made. These 255/85s don't rub and my truck sits lower than stock. The front springs are very negatively arched. Not much room to stops. I've been sitting on a 6" lift/37/12.50 Super Swampers I was going to install on a truck I sold. The plan has been to put all that on my '72 just to use it. I've come around to preferring it not so big,but figured I'd wear them out,then sell lift,install shorter one,and smaller tires. Well,now I've decided to just sell that stuff and lift less. It's hard to tell what an xx" lift would do since I'm not sure how much lower than stock I am now. I have a set of 9.75 Hurricanes and a set of 9.75 slots,so I want a wider tire for those to switch around. Now that I see Rob's Stepside I think I'll be good with 4"
Old 07-24-2014, 11:49 AM   #12
WhiteWhale
WhiteWhale's Avatar
Sorry to cause confusion by adding the "r", I still seem to have VW tires on the brain as I was used to ordering the 165r15 back in the day. I actually do like the 255s you posted and will probably go with a radial in the end since the 9.00-16s look like they need the lift to fit on my 72. As you mentioned as I get older the big lifts/tires dont seem as appealing as they did when my back and knees were younger.
I will probably end up with a set of the 7.50-16 power king super tracktion "meat grinders" on the rear of my 65 Carryall to compliment the posi and help with highway rpm.
Im sure I will run the 9.00-16s on my 59 Dept of Labor long bed Chevy as they look like they will fit with no mods.
Thanks for all the replies!!!
Old 07-24-2014, 07:26 PM   #13
Oh yeah,that '59 will surely clear 9.00s
Old 07-24-2014, 09:28 PM   #14
1972RedNeck
The picture isn't very good, but they don't look to be unidirectional to my eye.
Old 11-27-2018, 06:25 AM   #15
Undone
Any problems with them being out of round?
Undone is offline   Reply With Quote
