02-25-2017, 03:01 PM | #26 |
Re: STOCK 67-72 Steering Wheels
Hey FirstOwner69, same question. What can be safely used to polish up the in painted wheels?
02-25-2017, 03:35 PM | #27 |
Mine was cracked in about every place imaginable. Every joint between the spokes and the hub or rim were separated.
It took a bit of work, but now it looks like new.
Dennis '70 CST/10 '55 Bel Air wagon |
02-25-2017, 04:09 PM | #28 |
^Wow djecst, that turned out nice^
Here is a perfect example of the grain wearing off 155,000 miles of comfort grip Smooth everywhere except where the hands don't touch it You can see how more is worn off on your left hand Probably because it is so comfortable to drive these with your elbow out the window. Gripping the wheel right in that spot |
02-25-2017, 05:20 PM | #29 |
I really just want to put a 67-68 wheel on my 72!
02-25-2017, 07:05 PM | #30 | ||
First, I used 400-1000 grit sandpaper to remove fine scratches. Following that, I buffed them with the white rouge compound and a soft flannel buff that I use as the final step in polishing stainless. I used VERY light pressure to avoid softening or melting the plastic. The buckles look new. You may want to practice first on something that's not as valuable as your steering wheel. |
02-25-2017, 08:08 PM | #31 |
Moderator
Mine, currently have a 65 Chevelle installed in its place. Grain worn down, no cracks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-25-2017, 09:10 PM | #32 |
Nice wheel. How are these different than a 69-72 truck wheel?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
02-26-2017, 04:01 AM | #33 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-26-2017, 11:32 AM | #34 |
My Burban had a 80's/90's steering column and wheel in it when I bought it. (Yes the 2nd photo is of the column I removed, nice upgrade!) That was one first things to go. I found a wheel listed on C/L with a bunch of other odd stuff. It took three weeks to actually talk with the people who listed it. When I finally got to meet up with them I found out the wheel had been hanging on the wall of her art gallery since 1977 along with a bunch of 50's Ford chrome bits and other stuff. She had painted it a Hunter green and under that it looks to be the correct color for my 503 green truck. We tried to get the dark green off but it didn't want to come off. It ended up black when my buddy who was helping with the rest of the steering column replacement painted it when he painted the column, so now I have two layers of paint to remove.
Has anyone successfully stripped paint off a wheel without damaging it? If so how did you do it?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-26-2017, 01:04 PM | #35 | |
As a side note the '94 leather Blazer wheel I mentioned in my post also had a cover on it when I found it in the junkyard. When I removed it, the wheel looked like it had never been used. |
02-26-2017, 01:47 PM | #36 | |
The replacement I bought may may have been painted. I say this not just because it's duller than my others wheels, but by the looks of the part number. If my junk wheel survives it, I think I'll try some brake fluid on the area, see what happens. If it's painted I'll have it soda blasted. What tools & materials do you recommend for buffing?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-26-2017, 04:17 PM | #37 | |
All the early 2 spoke wheels I've seen were like the one from my '69. It's possible that the later wheels were more like those I've seen in vans due to a change in supplier or a running design change. It's also possible that the reason more black wheels seem to have survived is that the black wheels were, as special-K noted in post 11, used in vans from 73-78 and may have been purchased to replace cracked wheels in trucks. Does anyone have additional info? See post 31 for buffing info. |
02-26-2017, 05:35 PM | #38 |
Carpe manana
From what I know the 69-72 wheels had part # 9749753 whereas the later style wheels (vans?) had part # 335212. The grain pattern differed between the two. I have the later style wheel on my k20 and it's just as shiny as the OEM examples I have for 69-72 but the rim diameter feels slightly larger - I like the grip feel best with this style.
There are also differences in the wheel hubs as shown in this thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=575539 Here's what was a NOS saddle 69-72 wheel that I bolted on to a painted tilt column in my green Blazer with a repro horn button (that's an old school sew up grip protector removed from an early 60s one ton suburban).
02-26-2017, 05:38 PM | #39 |
Carpe manana
Here is an OEM 69-72 wheel I removed from a low mileage motor home that came from WA. It had a sew up grip protector. Nice crisp grain and nice shine.
02-26-2017, 05:40 PM | #40 |
Carpe manana
Here's the later style wheel in my k20 - note how the grain pattern differs from the other. Same style as that shown in the top pic post #18.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 02-26-2017 at 05:51 PM. |
02-26-2017, 09:38 PM | #41 |
Thanks for the pictures, Pete. They show exactly the differences I was talking about.
Jim Last edited by FirstOwner69; 02-26-2017 at 09:46 PM. |
02-26-2017, 10:51 PM | #42 |
This is the sandalwood wheel I just replaced. Closest I could find was the repop in saddle, is ebay the only place to find anything in sandalwood?
02-26-2017, 11:16 PM | #43 |
I don't think there is a repop of sandalwood. The wheel that came out of my blazer in post 23 was just as bad as yours. They just didn't hold up. Saddle is the next best choice.
02-26-2017, 11:21 PM | #44 |
Here's a green one
Anyone out there have one with no cracks? |
02-26-2017, 11:25 PM | #45 |
That is what I thought, and thanks for the quick verification!
Jim |
02-27-2017, 12:28 AM | #46 |
Now I see the difference. All three of mine are like this one, only with little grain along the rim.
02-27-2017, 12:41 AM | #47 | |
02-27-2017, 01:38 AM | #48 | |
https://garage.eastwood.com/videos/?...sc&wpv_paged=1 Here's another Eastwood link that shows a small canton flannel buff on a die grinder that would probably do the trick on plastic in lieu of expensive equipment: http://www.eastwood.com/canton-flannel-buff-wheel.html Last edited by FirstOwner69; 02-27-2017 at 01:47 AM. |
02-27-2017, 01:43 AM | #49 |
That looks nice!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-27-2017, 02:06 PM | #50 |
67 custom
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
