Old 03-09-2017, 08:19 PM   #1
63frankintruck
L31 assembled w/out crank stator?!?!!!
I installed a Ramjet cam in my L31. When it came time to reinstall the timing cover, I pulled the stator from the crank.see pic
(i figured it was not needed because I'm not using a computer to control the motor - soooo no need for a stator. RIGHT??)
Now my buddy at work told me that the stator was probably used to put pressure on the cam gear at the crank. Arg...
My question- Do I need to tear this down and reinstall the stator?
Thanks in advance for any help.
63frankintruck is offline   Reply With Quote
Old 03-09-2017, 09:39 PM   #2
B. W.
B. W.'s Avatar
Re: L31 assembled w/out crank stator?!?!!!
Yes, needs to be in there. Someone may make an aftermarket spacer? Never looked in to that.
B. W. is offline   Reply With Quote
Old 03-09-2017, 09:58 PM   #3
truckster
truckster's Avatar
I believe you can just run a standard SBC balancer and be fine. The Vortec balancer is shorter to allow room for the reluctor.
truckster is offline   Reply With Quote
Old 03-10-2017, 01:26 AM   #4
Captainfab
60-66 Nut
If you are using the L31 balancer, that reluctor ring, or an equivelent thickness spacer must be between the balancer hub and the timing chain gear. Without it, your pulleys will not line up. Also I'm not sure if it will positiion the seal on the balancer hub to an area where it could leak?
Old 03-10-2017, 01:51 PM   #5
Tom
driving is in my blood
Tom's Avatar
I ran a vortec pullout in my 79 and removed the reluctor ring as I ran carb. I also changed the timing cover to a standerd small block metal cover. I don't remember ever using a spacer to make up for the reluctor ring. Perhaps I used a standerd balancer.....
Old 03-10-2017, 08:51 PM   #6
63frankintruck
thanks guys for all the feedback, I got off work today early so I decided to go ahead and remove balancer, water pump, and timing cover.
Stator is now back in place.
Anything I should be aware of now before I seal this thing back up?
Old 03-10-2017, 10:06 PM   #7
87Skier
87Skier's Avatar
I did the same thing...
The worst part is that you have to drop the pan at least an inch to get the cover back in place.
I would say make sure you seal those corners (where block, pan and timing cover meet), and I've heard of people using rtv all along the bottom lip of the timing cover. Mine leaks but I only did the corners, next time I'm putting rtv along the bottom as well.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 03-11-2017, 01:04 AM   #8
'63GENIII
'63GENIII's Avatar
Did you replace the timing chain when you installed the cam? If so, which kind did you use? Reason I ask is that I found that there were 2 different timing chains for the Vortec that I just built. One was for use with a reluctor and one for without. Difference was 1/4" thicker for use without reluctor. Same balancer used in both applications.
Had I used the wrong timing set (which I ended up returning), the balancer would have stuck out 1/4" if I were able to get the cover on. Never tried to install it. Just happened to notice the difference between the old and the new one when they were both sitting on the work bench together. Otherwise would have never known.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-11-2017, 03:57 PM   #9
63frankintruck
Can someone verify where the timing marks are supposed to be ( the cam mark in relation to the crank mark) before I button this thing up?
by the way-
I did not change the chain ( all original equipment)
and I will be using a bead of high temp silicone for me gasket to pan.
Old 03-11-2017, 04:57 PM   #10
James the III
A buddy asked me what the crank bolt size and thread pitch was on the vortec..And I wasn't 100% sure..
any idea
James the III is offline   Reply With Quote
Old 03-11-2017, 08:52 PM   #11
63frankintruck
any idea
looks like 7/16 x 20
Old 03-11-2017, 08:57 PM   #12
63frankintruck
anybody on the timing marks?
Old 03-11-2017, 11:57 PM   #13
'63GENIII
'63GENIII's Avatar
Should be pointing directly at each other if stock. Only time it might be different is if you have a set that is keyed for advance or retard of the cam. If its a stock set, point them at each other.
Chris
'63 k15 long step
Old 03-12-2017, 09:48 AM   #14
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I've never read anything to suggest anything different than what we're used to on a GEN I small block. with #1 at TDC (of course) you can install the sprockets at 12 o'clock and 6 o'clock (dot-to-dot) or 12 o'clock and 12 o'clock. remember dot-to-dot is firing #6 cylinder, the other is firing #1. can make a difference when setting valves
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-12-2017, 06:36 PM   #15
63frankintruck
confused.... With #1 on compression stroke (TDC) is it dot to dot 6 o'clock and 12 o'clock or 12 o'clock and 12 o'clock
It can not be both can it?
Old 03-12-2017, 07:19 PM   #16
Bigdav160
Bigdav160's Avatar
dot to dot is compression stroke #6
Cam and crank at 12 o'clock is #1 on compression.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-12-2017, 10:06 PM   #17
fleetsidelarry
Senior Car Nut
Bigdav did a better job of explaining than I did, sorry. if you start out adjusting your valves thinking that, because the damper and the timing tab show you're at TDC, you're good to adjust #1 cylinder, you may be wrong. I keep this saved to my favorites:
http://www.chevytalk.org/fusionbb/sh...?post/2071722/
Larry
