Old 10-25-2012, 10:30 PM   #1
ccrane0044
ccrane0044's Avatar
blower motor relocation or removal
Hi there. I am currently building a 1980 c10 and bagged it with 22's and having fitment issues with the blower motor case. Was wondering if anyone else has ideas on what I should do as to removing the blower motor, relocating it or fabricating it to make it work. Also what problems some people may have ran into due to relocating it.
Thanks for your help,
Calvin
ccrane0044 is offline   Reply With Quote
Old 10-26-2012, 11:46 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: blower motor relocation or removal
Welcome to the site.
Relocating it is hard due to size. Consider and aftermarket under the dash blower assembly. Kits are mostly made for 67-72 trucks. Those kits will easily fit our trucks when the ducts are removed.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-26-2012, 11:52 AM   #3
ccrane0044
ccrane0044's Avatar
o kk, i was thinking about looking into that but it also sounds expencive and being only 21 years old and already sinking every dollar i have into this project, i have been looking towards the budget side of things. With that being said i will defiantly consider this option though. Are you aware of any sites that sell these?
Thank you for the help.
Old 10-26-2012, 12:04 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Since your from Canada you probably don't use a/c that much but I will assume you want to retain your heater and defrost. Look for a factory non a/c truck. It will have a much smaller blower motor and cover that was designed to fit closer to your firewall. Beyond that you will need to remove it and go with a hidden unit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-26-2012, 12:12 PM   #5
ccrane0044
ccrane0044's Avatar
My truck currently has the blower motor without a/c and even with that when I deflate the bags the tire does not clear at all so I'm assuming a underdash assembly may be my only option.
Thanks for the advise though. Much appreciated.
Old 10-26-2012, 08:08 PM   #6
rusty76
rusty76's Avatar
I know on another site a guy suggested using a Mojave unit. They're small and functional. I don't know anything about them but if you only need heat then you're in.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-26-2012, 09:01 PM   #7
ccrane0044
ccrane0044's Avatar
It's not so much heat that I want time keep functional. I just want to be able to have defrost functional incase the windows get fogged up at some point. But I will look into that system. Thanks.
Old 10-26-2012, 11:53 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Post some pics dude.
Articles-
"Refining Sierra"
Old 10-27-2012, 12:21 AM   #9
king-918
king-918's Avatar
Can't you use one from another vehicle? I kind of remember that from some Time ago
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 10-27-2012, 09:20 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Calvin
Hi welcome......seen them in stock too
http://www.princessauto.com/pal/cate...illary+Heaters
might help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
