Old 12-24-2019, 05:08 PM   #1
LTZMAN
LTZMAN's Avatar
2018 LT5.3 into 66 PU
Back in 1984 my dad traded a 57 chevy for this 1966 pickup. A few years later he painted it red, Back in 2012 we took it apart to replace the normal rust spots, I built a 383 engine and a 411 posi rear. We also put 2012 interior, tilt wheel,5 lug with disc brakes, and power steering.
Two months ago at breakfast he told me he was hearing a rocker arm noise
we loaded on my trailer and took to my shop. At this time he hands me the keys at 74 and said its mine now... Long story short, bad cam and lifter. This put me on craigslist looking for a ls engine. I located a 2018 L83 5.3 with 9300 miles on it. it came with a 6 automatic. These engines come factory with 355 hp but all 5,3s after 2014 dont have power steering, they have electric steering.
I worked 3 hrs on the firewall sheet metal today. I didnt like the valve covers hitting the firewall. now for some pics....
LTZMAN is offline   Reply With Quote
Old 12-24-2019, 05:19 PM   #2
LTZMAN
LTZMAN's Avatar
Re: 2018 LT5.3 into 66 PU
more pics, not sure why the pics are sideways after posting.
Old 12-24-2019, 06:12 PM   #3
LTZMAN
LTZMAN's Avatar
This started 4 weeks ago.
Old 12-24-2019, 11:09 PM   #4
Captainfab
60-66 Nut
Nice looking truck
You don't see many that aren't lowered.
Old 12-24-2019, 11:21 PM   #5
65c10restomod
Wink Re: 2018 LT5.3 into 66 PU
Its still power steering just not hydraulic like the earlier ones. truck
65c10restomod is offline   Reply With Quote
Old 12-26-2019, 11:09 AM   #6
cj847
cj847's Avatar
Bummer. I think your point here is that you are going to have to come up with a drive system to run your PS pump, or switch to electric. Both are expensive in aftermarket.
Don't the HD trucks (2500 and up) still run hydraulic? Maybe there is a factory piece you can find.
cj847 is offline   Reply With Quote
Old 01-09-2020, 05:45 PM   #7
LTZMAN
LTZMAN's Avatar
I made some progress on the chassis, we sprayed epoxy black, blasted engine stands.
Old 01-09-2020, 08:40 PM   #8
LTZMAN
LTZMAN's Avatar
Pics
Old 01-12-2020, 11:13 PM   #9
LTZMAN
LTZMAN's Avatar
Had a good day on the Lt install today, It help is was
70 degrees
Old 01-12-2020, 11:15 PM   #10
LTZMAN
LTZMAN's Avatar
Pics
Old 01-13-2020, 10:33 AM   #11
88Stanger
88Stanger's Avatar
70 degrees...... oh nice rub it in. LOL
Nice truck and i love the LT install. I am very interested in how the LT install goes. That is the next step up from the LS line. Please update us on how the install goes. Really interested in what you do for the wiring harness.
88Stanger is offline   Reply With Quote
Old 01-17-2020, 09:13 PM   #12
LTZMAN
LTZMAN's Avatar
Thank all of you for the kind words about the truck. When I purchased the engine ,I thought I was doing my second LS swap.I quickly learned I was in LT engines.
I put the HOTWIRE harness on last night. I will be installing the fuel pump and inline fuel filter Saturday. I ordered the brackets from CPW in FL to mount the ac,ps and factory alt on the pass side. Keep the replies coming.
Old 01-19-2020, 08:12 AM   #13
LTZMAN
LTZMAN's Avatar
I hope to finish up the fuel system today, I was dreading it.
Here are the pics I have on my cell
Old 01-19-2020, 08:16 AM   #14
LTZMAN
LTZMAN's Avatar
More pics
Old 01-19-2020, 08:20 AM   #15
LTZMAN
LTZMAN's Avatar
Pics
Old 01-19-2020, 07:51 PM   #16
LTZMAN
LTZMAN's Avatar
I'm going to try to post pics that are not side ways.
Old 01-19-2020, 07:54 PM   #17
LTZMAN
LTZMAN's Avatar
Pics
Old 01-19-2020, 08:01 PM   #18
LTZMAN
LTZMAN's Avatar
Fuel pump 90psi. The direction with the pump tell me to drill a 1/32
HOLE IN THE BRASS plug. The bit broke right before breaking through the plug. D##n
Old 01-19-2020, 08:06 PM   #19
LTZMAN
LTZMAN's Avatar
Ac ps alt bracket from CPW in FL. Waiting for it to complete the install.
Old 01-20-2020, 01:53 PM   #20
cj847
cj847's Avatar
Good to see someone makes a drive for this engine. What is the pump located where the PS pump would normally be? And why does it have its own drive off the crank?
Old 01-20-2020, 02:59 PM   #21
LTZMAN
LTZMAN's Avatar
Everything pulls off one belt to the crank.
The only exception is the vacuum pump has it's own belt.
Old 01-27-2020, 04:21 PM   #22
LTZMAN
LTZMAN's Avatar
We started her this weekend, I took the fuel relay out to check if it was going to turn over, it started on the fuel in the engine pump. Scared the hell out of me.
Old 01-27-2020, 04:28 PM   #23
LTZMAN
LTZMAN's Avatar
Pics
Old 01-27-2020, 06:51 PM   #24
Clyde65
Clyde65's Avatar
Nice! I did an lt, l83 in my dads crewcab, he loves it!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-03-2020, 06:25 PM   #25
66ChevyMax
66ChevyMax's Avatar
Surprise starts are never fun, kinda like hot wall plugs that you thought you turned off at the breaker
Very nice truck!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
