04-22-2016, 09:45 PM | #1 |
Caster for '79 Dana 44
What is normal factory caster for a 1979 Dana 44 in a K10?
Did GM increase the factory caster between 1961 and 1980? |
04-23-2016, 12:43 AM | #2 |
Re: Caster for '79 Dana 44
I think normal is about 2-3 degrees
04-23-2016, 01:35 PM | #3 |
Doesn't the closed knuckle have less camber as only manual steering was avl? I added some 4deg shims to try and get some more feel in the steering. Haven't driven it yet. My 72 Blazer i had back the late 70's didn't steer perfect if i remember right, kinda loose. Red-Head steering said they would build me a box to add some feel to the steering. I already have a new box, so that's not going to happen. I had a 77 Ramcharger 4x4 new and it steered perfect. Don't know what was in it. dana44?
1961 chevy K10 my build is------------61K10 build |
04-23-2016, 02:33 PM | #4 |
Kimble,
Thanks, for your knowledge/ experiance with caster/ drive ability of newer '79 4x4 front axles versus the closed knuckle ones of the 60s. The mid 80s Blazers steering/drivability was good too, with the 10 bolt front axle. Any more information on when GM made changes to the Dana 44 and/or 10 bolt front axles to make them steer/drive better? Any chronology of changes, or all at once. Thanks, Les Last edited by aotte1; 04-23-2016 at 02:40 PM. |
04-23-2016, 09:04 PM | #5 |
Between 4 -7 degrees
04-24-2016, 12:05 PM | #6 |
so the question has not been answered yet. Is there a difference in caster on a 60-67 dana44 closed knuckle compared to the open knuckle Dana44 or the gm 10bolt? I really don't know.
04-25-2016, 11:50 PM | #7 |
I would like to know also?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
04-28-2016, 09:25 AM | #8 |
I'm not sure what the factory spec on the closed knuckle axles were.There may be a small difference due to the kingpin style vs. the ball joint. Both will be within the range of 3-8° so one will work in place of the other, but you may still need to tune for the best result.
04-28-2016, 11:07 AM | #9 |
Obijuan and RR
Thanks for information, my '79 Dana 44 look like it has a bunch, maybe around 8 degrees. Just installing now, so no measurement yet. RR how do you tune on them, spring wedge? Kimble my '64 did not look like it has much? Les |
04-28-2016, 11:57 AM | #10 |
I don't have an O/K to compare with my closed one. I put a deg. wheel on the king pin bolts and it was about 3deg. not a good way to ck i guess.
04-28-2016, 11:47 PM | #11 |
Kimble,
Is your 3 degrees with additional caster you added via the wedges? I will try to get the '79 O/K measured. Les |
04-29-2016, 07:38 AM | #12 |
Castor specs for factory 4wd trucks:
63-68 3 degrees 69-76 4 degrees 77-91 8 degrees There is not a different spec for power steering/non power steering trucks |
04-29-2016, 12:13 PM | #13 |
Thanks a bunch 95 S Trucker. 60-61 probably the same as 63-68. So Les you should be fine without any shims. That may explain why my 77 steered better than my 72.
