Old 03-14-2017, 10:43 AM   #1
Wildhorsefarm
72 k60
Im needing to know what front differential fits K60? Also know to find one?
Wildhorsefarm is offline   Reply With Quote
Old 03-14-2017, 10:52 AM   #2
kwmech
Re: 72 k60
Rockwell or a Marmon/Herrington would be my guess
Old 03-14-2017, 01:37 PM   #3
sweetk30
sweetk30's Avatar
Re: 72 k60
that old most likely eaton .
try the heavy hauler section .
I just had a thread up on a 1969 c-60 with napco power pak conversion from back then .
most of them I have read up on and the 1 I worked on are 7.20ish ratio gear . with 39" tall tires . and a Rockwell divorced 223 t-case .
so your going to want a matched pair of axles . time to time there on ebay I have seen but getting parts can be a bit hard . and info is almost non existent on the big stuff like these .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-15-2017, 02:09 AM   #4
andrewmp6
Re: 72 k60
This part of the forum http://67-72chevytrucks.com/vboard/f...play.php?f=239 might know they love those huge trucks.
Old 03-15-2017, 06:33 AM   #5
Wildhorsefarm
Re: 72 k60
Thanks for the help. I decided to install a matched set from aM35A2 deuce and half . Since this is now a 6 door cab.
Old 03-15-2017, 10:09 AM   #6
sweetk30
sweetk30's Avatar
Re: 72 k60
and you get 6.72:1 gear ratio .
good axles with lots of support for parts or upgrades.
only thing to watch is the top loader design = clearance for the oilpan and other items that might be in the way . that diff center sticks up there.
Old 03-16-2017, 06:28 AM   #7
Re: 72 k60
No such thing as a '72 K/60. It all depends on which conversion was used and then it's a complete steering drive axle, not just a differential. Rockwell 2.5t axles are your best bet for multiple reasons, if you are building one.
