Old 04-16-2018, 10:41 AM   #1
85/Silverado
85/Silverado's Avatar
Posi Rear End
I want to switch my 10 bolt stock rear gear to a slip posi. and was wondering how many teeth are on the rear axles so I get the correct Differential (30 or 33)? The one that's in the truck is a 2.73. and with my motor I get no traction so I'm hoping the posi will help.
Should I go for the Posi 2.73? I only get 8 mpg as it is.
1985 Silverado
383 Stroker 425HP+
TH 350 B&M shift
12" wide rear tires
85/Silverado is offline   Reply With Quote
Old 04-16-2018, 11:09 AM   #2
nonstop
Re: Posi Rear End
Factory rear I believe is 28 spline. Only way to know for sure will be to pull an axle and count, as who knows what’s been changed in 30+ years.
As for gearing, you may want to actually consider stepping to a lower gear. Depending on cam and engine specs, you could be below the engines power band. You could actually see an increase in mileage with lower gears.
nonstop is offline   Reply With Quote
Old 04-16-2018, 11:17 PM   #3
Captainfab
60-66 Nut
Re: Posi Rear End
If your 383 is a true 425hp, you definitely need a lower gear than 2.73. You're never going to get good mpg's with 425hp pushing a brick down the road, but you should be able to get over 10 mpg.
Old 04-17-2018, 04:20 PM   #4
85/Silverado
Re: Posi Rear End
maybe a 3.73?
Old 04-18-2018, 12:33 AM   #5
Captainfab
60-66 Nut
Re: Posi Rear End
Possibly. It depends on how your engine is built. What cam is in it? Do you have a stall converter? What size are your rear tires?
Originally Posted by 85/Silverado View Post
maybe a 3.73?
Old 04-18-2018, 09:18 PM   #6
85/Silverado
Re: Posi Rear End
Rear Rims 18x9.5"
Tires 235/50R18
2500 stall converter on a new TH 350 B&M shift kit tranny.
Old 04-19-2018, 12:18 AM   #7
Captainfab
60-66 Nut
Re: Posi Rear End
OK, your tires are only 27.3" in diameter and that cam is somewhat mild for a 383. I would probably go with a 3.07 gear. That will keep your rpm's reasonable at highway speeds plus it should help with the mpg's and possibly help a little with the traction issue. Of course a posi will also help with the traction issue. That would be my recommendation. You could go with 3.42 gears, but that is going to raise your highway rpm's a bit.
Old 04-19-2018, 12:16 PM   #8
85/Silverado
Re: Posi Rear End
Thanks Cap.
I loved your town when I lived in Spokane. Used to go down under the freeway bridge and jump off the cliffs. Fun days in 80 to 84.
