07-20-2008, 04:53 PM | #1 |
Hydraulic Clutch Conversion 1965C10
Hey guys,
Here is one way to add a hydraulic clutch master cylinder to a 65C10. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-20-2008, 05:05 PM | #2 |
Re: Hydraulic Clutch Conversion 1965C10
Here are the last two pics.
TR
07-20-2008, 05:25 PM | #3 |
Nice setup!
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
07-20-2008, 05:36 PM | #4 |
I'm wondering how that would work out for the 62 trucks (so that I wouldn't have to spend $500 on a dual MC for power brakes and my clutch)
Do you have sourcing, part numbers, pricing, etc. on these pieces? Very nice BTW, very very nice. |
07-20-2008, 07:49 PM | #5 |
Kevin,
The Wilwood master cylinder is 260-3374 Summit Racing $66.88 shown in the picture. The heim joint is 6072K165 5/16dia. 5/16-24 thread RH 3200# capacity $5.47 McMaster Carr The shoulder bolt is 91259A578 5/16dia. 1/2" long, 1/4-20 thread $1.09 McMaster Carr That was all there was to buy except the bar stock, bolts and nuts, and of course the hydraulic line to the slave. Pretty inexpensive solution. TR
07-20-2008, 11:00 PM | #6 |
No problems with the firewall flexing?
07-21-2008, 10:07 AM | #7 |
Post Whore
How does the slave mount? Very nice install. I'm using a 1989 1 ton's hydraulic clutch setup on my 69 K20.
How does the effort needed to work the clutch compare with the stock setup? A boardmember with a bad knee was asking about that issue so this will be informative to him.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
07-21-2008, 11:19 AM | #8 |
TR, thanks very much. That is some very nice work.
07-21-2008, 02:56 PM | #9 |
Thanks for the kind comments men.
Jack, I haven't actually installed the transmission yet, just getting ready while keeping the truck on the road. I expect clutch effort to be pretty light since it should be the same or less than a current Vette, GTO manual clutch and the clutch pedal is a little longer on the truck. The slave is a current stock T56 center pull mounted in the bell housing around the main shaft. Quicksilver, The firewall is quite rigid in that area due to the re-inforcing channel to the right and the contour to the left. No visible flexing. TR
07-22-2008, 11:50 PM | #10 |
60-66 Nut
Very nicely done TR65
07-23-2008, 07:52 PM | #11 |
Manual Transmission Club
Thanks for that. I'm looking to put a NV4500 in my 79 sierra, I'll have to save this post for when I'm ready.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
07-23-2008, 08:05 PM | #12 |
Excellent job dude. Where'd you get those pressure gauges? What is the range?
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
07-23-2008, 09:09 PM | #13 |
Anthony,
The gages and adjustable proportioning valve are from SSBC (Stainless Steel Brake Corp). The range is 0-2000psi. I want to see the split between front and rear brake pressure (4 wheel disc). I set it at one number for unloaded so both axles lock up at the same time, less split for loaded. Oh, and I like gages. TR
07-23-2008, 09:18 PM | #14 |
Interesting.............Would like an update on how it works!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
07-23-2008, 09:41 PM | #15 |
Cool, looks trick to me, but then I like gauges too. Did you have to flare the end of those lines, or are those compression fittings? Sorry, I'm nosy like that. :-)
07-24-2008, 03:30 PM | #16 |
Anthony,
The lines use inverted flare fittings. TR
04-16-2009, 11:48 PM | #17 |
very nice write up as usual TR!!
CHEVY ONLY |
01-31-2010, 12:06 AM | #18 |
Well guys, I finally got my new engine and transmission installed so I can update this thread.
The slave cylinder is a center pull late model (2005) with no bleed screw. I used my one man brake bleeder attached to the bleed screw on the master cylinder. I am using silicone fluid. All I had to do was the pump the clutch pedal for a few minutes until all the bubbles stopped coming out, done. Since the master cylinder mounts level no bench bleeding was necessary. Tip. The actuator rod should line up level with the master cylinder at the bottom of the stroke, not the top as in the above picture. So when it was pushed in all the way it was rubbing. So I had to elongate the hole in the pedal to fix that. The pedal effort is fairly high, pretty much like the mechanical clutch that was in the truck. You could use a smaller bore master cylinder to reduce the effort if you wanted. It will be a couple of months before I get the engine running so I can see how the release feels. TR
01-31-2010, 03:28 PM | #19 |
Well written and good pics, glad you brought that BTT, I'll be doing a '66 this Spring. Thanks!
02-05-2010, 01:24 PM | #20 | |
what keeps the bolt in place with the elongated hole now? Can't it move around in such a big hole? Why did you choose to make a new hole in the first place? Wouldn't the factory hole give you the precise original throw? thanks for the help, just got a T 56 - Dan |
02-19-2010, 04:09 AM | #21 |
Addicted user
This may seem like a goofy question but how/where do you get a slave cylinder on which you mount to the actual clutch?
(from what i have tried to read up on was the slave cylinder is called a hydraulic throwout bearing? ) Is that what the slave is?? I see you wrote you got a slave from an 2005 model something... some pics of that setup would be great as I would really like to put a hydraulic clutch on my older muncie transission... thanks! |
02-19-2010, 10:59 AM | #22 | |
The Few, The Proud
I installed a hydraulic slave cylinder on SM465 4spd. There's a company called Novak that makes the kit. Here's a link for the kit I'm using. http://www.novak-adapt.com/catalog/kit_hcrc.htm Here are a few pictures of what it looks like installed. I hope this helps.
Shannon |
02-20-2010, 12:26 PM | #23 | ||
No problem with the elongated hole just tighten the bolt sufficiently. I had to elongate the hole due to my mistake so I hope somebody else can avoid that. I am driving the clutch cylinder from the left side of the pedal. The factory mechanical clutch goes thru the pedal mount pivot and drives a lever arm on the right side of the pedal. So there is no factory hole for what I am doing. By the way, the T56 shifter is way back and would come up under the bench seat of our trucks. If you have buckets it can work. You can move the shifter position which is what I did. (It is a major undertaking though) http://67-72chevytrucks.com/vboard/s...d.php?t=300892 Quote:
The T56 uses a center push slave cylinder that mounts around the input shaft of the tranny. The transmission needs to be made for that. Shannon's setup looks sweet for a traditional style clutch slave!! I would think that you could also use the factory hydraulic slave setup that was used on the older trucks. TR
02-20-2010, 08:13 PM | #24 |
Addicted user
Thanks guys, thats exactly what is was wondering and looking for..
The only problem I have now is I can't really mount an external slave cylinder as I got a set of those Sanderson shorty headers from ECE and they don't fit around the stock Z bar AND... they dump right above the fork so its pretty hard to get a bend in there to clear the fork and linkage, an external slave to be almost impossible as they hug the block. What kind of hydraulic internal / throwout bearing can i use??? Anyone use something on there manual trans instead of the stock fork?? My 4 speed is dated around 1977.. not sure if this matters or not. |
02-20-2010, 08:55 PM | #25 | |
