Old 08-17-2002, 12:35 AM   #1
Twilightoptics
Intake Manifold Underside Oil deflector/baffle
Is this REALLY necessary? I had my manifold sandblasted and there is a bunch of sand inside it. Friend of mine says its just to keep oil off the top of the manifol to cool it all of 3 degrees. If so then I don't see the urgancy of keeping it on! Thanks?
http://4.65.252.68/hosted/twilightsig.jpg
1967 Chevy Pickup:
'85 Camaro 305
Rebuilt carb - Turbo 400 Trans
Flowtech headers to Purple Hornies
Twilightoptics is offline   Reply With Quote
Old 08-17-2002, 01:34 AM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
aftermarket (edelbrock and such) intakes dont have it, so i doubt it would matter if you removed it
68SWB4x4 is offline   Reply With Quote
Old 08-17-2002, 02:30 AM   #3
matt67350
matt67350's Avatar
Exclamation you need it
If there is sand in the baffel, you have to get it out.
A small chisel and hammer will wiggle the keepers out. Then clean the manifold and baffle with brake cleaner. The sand will kill your motor! The baffel is used to reduce heat to the intake under the carb.
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
