Old 02-14-2018, 05:18 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
Pictures of my rear end
Okay, I'm not going Harvey Weinstein on you, I just need help identifying this pinion yoke so I can get u-joints and make a driveshaft. It's a GM 12-bolt but the pinion yoke seems non-standard. Those cups are 1-1/16" but that's supposed to be an outside clip u-joint but there are no retaining tabs. My local driveline guy suspects someone ground off the retaining tabs. I'm much more familiar with Ford rear ends; any classic Chevy guys help me out?
MiraclePieCo is offline   Reply With Quote
Old 02-14-2018, 05:38 PM   #2
mongocanfly
Re: Pictures of my rear end
whewww ....that's a relief....I didn't know where you were going with this...haha
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
mongocanfly is online now   Reply With Quote
Old 02-14-2018, 05:53 PM   #3
MiraclePieCo
Yeah, but I notice you clicked on it, ha ha!
Old 02-14-2018, 06:14 PM   #4
DransportGarage
DransportGarage's Avatar
This rear end does NOT look like the original one in my '55 sedan.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 02-14-2018, 06:48 PM   #5
MiraclePieCo
Here's a better pic with dirt cleaned off. It appears to have the tabs ground away.
Old 02-14-2018, 06:48 PM   #6
mongocanfly
yeah.....I guess I did didn't I.....haha
Mongo...aka Greg
Old 02-14-2018, 09:25 PM   #7
1project2many
Tabs are ground off. Get another yoke.
1project2many is offline   Reply With Quote
Old 02-15-2018, 04:28 AM   #8
MiraclePieCo
I think you're right. Why the _____ would someone do that?
Old 02-15-2018, 05:31 AM   #9
DransportGarage
Because they dropped a ____ needle bearing (or two) into the bottom of the cup, then thought the joint was too long for the ____ pocket.
Bob
Old 02-15-2018, 07:09 AM   #10
Jesse Z
Sounds like the voice of experience, lol!
Jesse Z is offline   Reply With Quote
Old 02-15-2018, 01:19 PM   #11
DransportGarage
Yeah, well, I screwed up a lot of stuff in my younger days. I never ground out the tabs though. I just fixed the bearings.
Bob
Old 02-15-2018, 04:01 PM   #12
whitedog76
Would an inner c-clip style u joint help him?
whitedog76 is offline   Reply With Quote
Old 02-15-2018, 04:24 PM   #13
1project2many
Could be the above suggestion, or it could be that the kid at the local Parts Superstore sold the wrong U-joint and the owner decided to make it work.
Possibly. I don't know if there are any inner clip style U-joints which would fit into that yoke.
Old 02-15-2018, 05:00 PM   #14
whitedog76
Here's a list of U-joints from Randy's Looks like there is a bunch of different styles and spreads. Assuming that it's a 1310, 1330 would be different yet.
https://www.ringpinion.com/b2c/Parts...ID=5&CatID=104
Old 02-15-2018, 10:57 PM   #15
mr48chev
mr48chev's Avatar
When you save and expend the last photo that is super clear you can see what's left of the tab on the right hand side where I circled it. If you were desperate you could build it up with weld and then take a Dremel tool or die grinder to it but that is a bit chancy. The price of a new yoke is probably inexpensive insurance against problems or vibrations.
My ongoing truck projects:
Old 02-15-2018, 11:22 PM   #16
MiraclePieCo
Yeah, I already ordered a new yoke. Shame the PO had to ruin a $100 yoke instead of buying a $15 u-joint. Evidently he just centered the u-joint by eye, then clamped it down. Doesn't sound safe to me.
Old 02-16-2018, 11:12 AM   #17
DransportGarage
Here's a Craigslist listing of a rear end that looks a little like yours. Even has the square bosses near the axle tubes.
https://cincinnati.craigslist.org/pt...474420966.html
Hope this helps in identifying your yoke.
Bob
Old 02-16-2018, 04:11 PM   #18
mr48chev
mr48chev's Avatar
They do walk amongst us. Same kind of guy who will bust a 100 dollar part in a wrecking yard to get to a part that might sell for 2.00 .
The way my luck runs if I had tried to run it that way the U joint cup would have slipped sideways and I'd have the driveshaft shaking and baking as I went down the road.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
