Old 01-02-2018, 08:01 PM   #1
Oscar the grouch
Oscar the grouch's Avatar
1984 k5
I have a 1984 k5 blazer and the power locks dont work. Im getting power to the plugs when i press the switch so I replaced the actuators and still nothing, but I did find the passenger switch not working is that keeping the locks from working 🤔
1970 chevy k10 305/4 speed
Oscar the grouch is offline   Reply With Quote
Old 01-02-2018, 11:04 PM   #2
Greenlee
Greenlee's Avatar
Re: 1984 k5
I’m not sure about the locks, but I had a similar issue with the power windows. My passenger window wouldn’t work at all because of a bad driver side window switch. I remember it seemed odd to me that it wouldn’t even work with the passenger side switch until I replaced the driver side switch. I guess power runs through the driver side switch to the passenger side.
Another thing you might check, is there are relays for the power locks mounted on the firewall in the area up behind the gas pedal.
Greenlee is offline   Reply With Quote
Old 01-03-2018, 03:38 PM   #3
wjjeeper
wjjeeper's Avatar
Re: 1984 k5
Check the wiring from the cab to the door....... They crack/ break from years of the doors opening and closing and it could be a matter of low amperage.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 01-03-2018, 03:53 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Re: 1984 k5
I've seen a few threads about the switches wearing out/poor contact.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-03-2018, 08:52 PM   #5
Oscar the grouch
Re: 1984 k5
I got the locks working the relay was just stuffed up out of the way, once I mounted it locks started working now to figure out the dome lights
