Old 11-06-2019, 09:54 AM   #1
jkk
jkk's Avatar
Who sells quality 3 in lowering springs?
Hey Guys
I have 2 in spindles and 2 in lowering springs wanting to drop another in would you recommend cutting the springs or replace them with the 3 in springs?
Anyone ever tried this setup?
jkk is offline   Reply With Quote
Old 11-06-2019, 01:33 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Who sells quality 3 in lowering springs?
Western chassis. I've run the setup for over 10yrs.
Old 11-13-2019, 12:08 PM   #3
Timtruck
Or cut off 1/2" from the total spring height.
Timtruck is offline   Reply With Quote
Old 11-22-2019, 01:23 PM   #4
Kudzupatch
Kudzupatch's Avatar
Or run a shorter tire. Helps with fender well clearance and easy swap.
Kudzupatch is offline   Reply With Quote
Old 11-22-2019, 02:22 PM   #5
MikeB
MikeB's Avatar
Keep in mind that 1" at the spring is approx 1.6"-1.7" at the wheel.
And if cutting less than a full coil, the spring won't seat on one end. I also suspect you'll hear creaks and groans when the end that's not seated moves around.
On another note, cut springs are stiffer springs. For example, a 2" drop spring will have a smoother ride that stock height spring minus one coil.
Bottom line: I like the idea someone had above about using a shorter tire.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-22-2019, 08:24 PM   #6
jkk
jkk's Avatar
I’m running 245/40/20’s at the moment
Old 11-25-2019, 01:25 PM   #7
Tom
Tom's Avatar
Running a shorter tire will increase the fender gap, which is what most people are trying to get rid of when lowering....
Old 11-26-2019, 04:42 PM   #8
Richard
Years ago right after I purchased my 94. I cut my brand new Eibach springs before I even put them on my truck. They did not make a 3" drop coil. I say go for it, worst thing that happens is you will need to get another set of coils. Be conservative when cutting the coil, you cannot put the material back. I would say start with about a half coil. I like to put the coil in a bucket of water with just the top sticking out and use a cutoff wheel. You may have to pull them in and out a couple of times to get right where you want, but it costs nothing but time and maybe a cutoff wheel or two. Don't forget to roll truck after setting it back on the ground so everything is settled where it goes. Good luck!
Richard
Thread Tools
Display Modes
