Old 01-28-2004, 04:49 PM   #1
Bluegoose972
Gas Tank Plumbing
I've installed a new gas tank for my blazer, replacing the old rusted and dented unit with a poly unit. So far, so good. Now I need to hook up the hoses....Not so good. Here is what I see:
On the passenger side, I have one 3/8" fitting, which I believe to be a vent. I connected this to the hard plumbing vent line on that side...no problem there.
On the driver side, in addition to the gas filler neck, I have two additional fittings....one 3/8" and one 5/16". I believe the 5/16" is for another vent hard line, which is located nearby. But what is the second 3/8" vent line for?
Does anyone have a picture that illustrates the correct plumbing for this unit? I been checking my misc manuals, but have yet to find anything that identifies what these three vent lines are for.
Thanks,
Rick
Bluegoose972 is offline   Reply With Quote
Old 01-28-2004, 05:53 PM   #2
smokekiki
Mike
smokekiki's Avatar
You should have a vent from the filler neck to the one fitting.I think the smaller line goes to a steel line that goes across the rear crossmember and runs to the charcol filter.Not sure about that.I don't have a charcol filter.I have the filler vent hooked up and the other on the driver side blocked off.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-28-2004, 08:56 PM   #3
k5hart
k5hart's Avatar
I just put a new steel tank in mine. Smokekiki sounds correct. There should be a filler vent hose that attaches next to the filler hose. My hose was actually two pieces with a small metal coupling in the middle. The other pass. and driver side small fittings hooked up as a vent and the charcoal filter. Heres a picture. Dont know if will help you.
[img]http://www.ranchoweb.com/public/i/?http://img.ranchoweb.com/images/k5ha...ishedtank6.jpg[\img]
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 01-28-2004, 08:58 PM   #4
k5hart
k5hart's Avatar
That link sure didnt work! Should have checked it first. Here you go:
Old 01-29-2004, 12:11 AM   #5
Bluegoose972
Thanks guys...Perfect information...Just what I needed!
Rick
