Old 08-04-2006, 04:04 PM   #1
HvyChevy
HvyChevy's Avatar
1970 4x4 Blazer Disc brake conversion
I have a 70 4x Blazer and looking to install disc brakes on the front. I was told that a 1977 front axle parts will swap over. Not the whole axle because it's slightly wider, but from the knuckles out will work.
Has anyone tried it? Or is there a better way?
(thanks!)
HvyChevy is offline   Reply With Quote
Old 08-04-2006, 04:17 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: 1970 4x4 Blazer Disc brake conversion
Just swap over the whole axle assuming the gear ratio is correct. Width is the same and spring perches are placed correctly. I'm putting a 78 3/4 ton front axle under my K5 for the same reason.
Oh, welcome to the board and that is one sweet K5!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-04-2006, 04:24 PM   #3
HvyChevy
HvyChevy's Avatar
Thanks YJ, that sounds easier.
Thanks for the compliments, it needs a little work. I just bought it a few weeks ago. The front springs are way too stiff (don't know what brand), it has a Mark IV a/c unit that I'm trying to get working, maybe a cross over steering set up in the future? Needs a roll cage too. A little rust on the bottom of the doors.....what fun would it be if it was perfect, right?
I guess there's always going to be a list of things to do to it...
Your truck looks cool...
Old 08-04-2006, 04:59 PM   #4
Jason915
Sweet 70K5, I too am getting ready for the disc brake conversion on mine. I have a 1975 D44 from a 75K5 with 3.73's ready to go into my K5. The cool thing about the newer D44 is that it has a factory sterring stablizer. My question is what brake lines will work. I know I have to change my master cylinder out.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 08-04-2006, 05:09 PM   #5
meathead95
computer illiterate
meathead95's Avatar
welcome from nashville! that is one awesome rig
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 08-04-2006, 05:12 PM   #6
Jason915
Oh yeah for your suspension I would suggest Skyjacker Softride they kick butt in overall ride quility.
Old 08-04-2006, 05:25 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Welcome from the Pacific NW. Nice lookin' rig (I'm partial to Orange with a white top!). I've heard the Rough Country is one of the stiffest lifted springs. I've had Rancho Lifts on three of my Blazers and it was stiff, but driveable. The tires make a huge difference too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-04-2006, 05:49 PM   #8
HvyChevy
HvyChevy's Avatar
thanks guys!!! I look forward to working on it.
I'll be sure to take pics and keep ya'll posted with the results.
Old 08-05-2006, 05:45 PM   #9
pound41
I have a 70 that I bought that has a newer disk front swapped in it. It was a factory power drum. To me it didn't stop as well as I would like with the old master and prop valve. I got the correct master and valve but had to do some engineering. Different size threads etc. You might want to consider the whole 3/4 booster swap. That is what I am doing.
pound41 is offline   Reply With Quote
Old 08-05-2006, 06:18 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-05-2006, 06:21 PM   #11
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! That's a very nice Blazer you have!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-05-2006, 08:36 PM   #12
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Welcome from Michigan, the home of rust. Nice looking ride.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 08-05-2006, 09:45 PM   #13
Southedisto
River life......
Southedisto's Avatar
Welcome to the board, and I would go with a complete axle swap instead of the knuckles out swap.
Southedisto is offline   Reply With Quote
Old 08-05-2006, 10:05 PM   #14
Livrat
Member #1049
Livrat's Avatar
Welcome to the board!!
Since 1970 is the first of the open knuckle dana 44's and the last of the drum brakes.. All you need to do is change from the spindles out... just pull off the calipers, remove the rotors.. then remove the spindles, pull out the axles from the 77.. and put it all in yours... Thats the easy part.. next is the brake lines.. the 77 stuff is not compatible... the easy way is to find a 71 or 72 chev 4X4 and use the brake lines.. the 70 lines drum brake lines come thru the frame behind the axle and the 71/72 comes out in front of the axle and uses different hoses.. you will need to drill the holes in the frame for the lines to come thru.. and use the hoses from a 71 to 80 4X4.. You will also need to change the master cylinder and booster to a "disc brake" one.. it does not matter if its from 2WD or a 4X4 as long as its from a 71/72 1/2 ton...
Hope that was not too confusing.. if you have questions.. feel free to PM me or email me directly.. Livrat@aol.com
Livrat is offline   Reply With Quote
Old 08-14-2006, 10:50 PM   #15
69TowRig
'69 and '70 Blazers had open knuckle D44s. My '69 was not closed knuckle like everyone says it should have been, and I have not seen a '69 K5 with closed knuckles.
The problem with a spindle swap is that drum-brake knuckles have the six bolt holes clocked differently than the disc knuckles do, so a straight spindle swap is not quite so simple. The disc-brake backing plate will put the caliper in contact with the knuckle itself. You *could* grind away a lot of material and make the caliper fit, or swap the entire knuckle off.
If you do the knuckle swap, you can use any 1971-later D44 or Coporate 10-bolt for donor parts. It is closest to "bolt-on" if you use the matching outer axleshafts from the donor axle.
I did the knuckle swap last year on mine. I pulled the knuckles from an '84 K5, bought reman calipers and paid up for a set of Crown brake lines through xtremecrawlers.com. I re-used my original outer axleshafts but was not able to install the retaining clip for the shafts under the lockout. If you go the same route as I did you end up needing 1" long 7/16"-20 bolts with fender washers to retain the axleshaft from moving back and forth (the ends of the shafts are threaded)
The knuckle swap will cost you some $$$, I had to replace the balljoints, an axleshaft u-joint, and a couple wheel bearings too. Lots of time invested. In the end you get disc brakes but still have the smaller u-joints ('73+ have larger axle u-joints). The spring perches are the right distance apart on the '73+ trucks, and it is a straightforward swap if you go that route. A bonus is that you automatically get the lower mounts for a swaybar if you want to add one of those to the truck as well.
Overall, with the power booster and discs up front the thing stops way better than it ever did before, and the effort is worth it.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 08-14-2006, 10:56 PM   #16
jakeslim
Premium Level Member
jakeslim's Avatar
My drums on front axle will stop on a dime............well maybe 4 dimes Welcome to this habit. Warning we may see ya on that show "Intervention" for a bad parts habit.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 08-16-2006, 06:14 PM   #17
HvyChevy
HvyChevy's Avatar
Thanks for the welcome, compliments, and info!!!
I found a 1980 4x4 front axle (well parts of one anyway....lol)
So, I'm going to give it a shot. I guess I need to try and find some beefy axleshaft u-joints.
Off Road Unlimited sells a cross over steering kit comes with a passenger side flat top knuckle, 2 wheel drive steering box, etc.....kinda pricey though. Well see.
Here's some pics of my parts pile.....Oh yeah, best part.. I found a '70 tilt column too...
Old 08-16-2006, 07:13 PM   #18
69TowRig
Good luck, PM me if you need any pointers. Looks like you didn't get the shafts so just "run what you brung". You will need to do the setup with the bolt I was talking about, but you will figure it out when you put it together.
BTW, sweet column, where'd you find that?
-Chris
Old 08-16-2006, 07:32 PM   #19
HvyChevy
HvyChevy's Avatar
Maybe I can still get the shafts. I picked up the parts before I read your post. I'll probably be pm'n ya. Thanks!
I found the column (after searching a few yards) at Truck Parts Co. a dismantler in Baldwin Park, CA
Old 08-16-2006, 09:18 PM   #20
69TowRig
Hmm, thinking some more if it was from and '80 then it was a Corporate 10-bolt. The inner shafts won't work because they are 19-spline instead of 30-spline like the Dana units. Not sure if there is a conversion joint for the axle u-joints either. You may just have to use what you have.
-Chris
Old 08-17-2006, 02:17 PM   #21
HvyChevy
HvyChevy's Avatar
Hmm....good thing I don't have to drive it everyday...I guess I'll start wrenching and see what happens. (Oh, the fun....lol)
Old 03-26-2021, 05:49 AM   #22
ohboy321
ohboy321's Avatar
(thanks!)
The only parts that will bolt in on a 70 D44 would be from a 71. They increased the axle and u-joint size starting in 72.
Duckduckgo the BOM (bill of materials) for the D44 and you can see the axle part numbers are different between 71 to 72, while 70 to 71 are the same. Sorry I don't have a link for the BOM, but the info is out there.
My K10 has a 70 Blazer D44 front axle, and I hope to convert to disk some day.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke
2007 BMW X3
2020 BMW 540xi
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
Old 04-01-2021, 08:43 AM   #23
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 1970 4x4 Blazer Disc brake conversion
Regardless of the thread age, this info is gold. On my 1970, I am just swapping the entire front diff from a 1972 to avoid mismatched parts.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 04-15-2021, 11:59 PM   #24
mthomlinson
I swapped 72 axle into my 70, The brake lines are a different size and go through the frame in a different location
mthomlinson is offline   Reply With Quote
Old 03-27-2021, 10:13 AM   #25
hemi43
hemi43's Avatar
You do realize you're replying to a 15 year old post?
hemi43 is offline   Reply With Quote
