09-27-2012, 10:01 PM | #1 |
Cheap temp speedometer
I have a post-1992 700R4 transmission in my 64C10, which I assume means it takes an electical speedometer. What is a decent cheap speedometer I can get until I get the money to buy all new matching gauges?
09-27-2012, 10:05 PM | #2 |
Senior Enthusiast
Re: Cheap temp speedometer
I'm not sure there are any cheap/decent electric speedos. From the reviews I've read the inexpensive gauges are rarely worth what they cost. I'd be more inclined to study all the different brands and decide what you're going to buy when you do have the money for a matching set, and then buy just their electric speedo for now. That way you don't have to replace it later, and run the risk that the type of sending adapter may have to be changed as well.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
09-28-2012, 12:29 AM | #3 |
60-66 Nut
This is about the cheapest I have found.
http://www.ebay.com/itm/Brand-new-St...1d74ba&vxp=mtr I just have not had any luck in my searching in finding out just what it takes to make that speedo operate. My next step was to send the seller a message and see if he has any info on them.
09-28-2012, 12:35 AM | #4 |
Compass app on a smart phone. I used mine for quite a while on my old dodge until I got a good feel for gear/rpm/speed patterns then just learned to flow with traffic until I got my real speedo working.
09-28-2012, 05:23 AM | #5 |
I never leave home without my Garmin. I know its no help with your question but the solution works for me until I get the new speedo gear.
09-28-2012, 07:38 AM | #6 |
We used our Garmin, as well. Also was very handy when programming new speedo.
09-28-2012, 08:04 AM | #7 |
Thanks for all the replies. I'm using Ulysses Speedometer on my phone and it works extremely well, but it kills my battery so I can't use it for a long time.
09-28-2012, 02:22 PM | #8 |
Never Ending Projects
Wouldn't it be cheaper to buy a car charger and put in a 12volt outlet and use your phone for now?
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-28-2012, 03:27 PM | #9 |
That's a good idea, exactly what I would do!
Posted via Mobile Device |
09-29-2012, 12:18 AM | #10 |
Been using an app for a while. Got the rpms pretty figured out...
09-29-2012, 02:27 AM | #11 | |
Here yah go, you can find them cheaper on Ebay BTW: http://www.speedwaymotors.com/Auto-M...Unit,5261.html Oh and if you don;t have a spot on your transmission for a cable hookup try something like this maybe: http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
Active Duty Air Force 02'-Current Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband "Family owned and operated since 1969" Dad's 66' Custom Camper - Big Family Small Budget Last edited by ozzyman; 09-29-2012 at 02:32 AM. |
05-13-2016, 11:43 PM | #12 |
But Found Her 25yrs Later!
This, or something similar will still be useful even after you get an in dash speedometer.
GPS Head-Up Display Speedometer (quick and easy installation) https://www.amazon.com/dp/B005X4QCAA..._00PnxbPQZ483Q
10-30-2017, 07:38 PM | #13 |
I've been using an android phone app.
It even works with an old phone that isn't tied to a carrier. It's called DigiHUD
10-30-2017, 11:07 PM | #14 |
Gps on your phone.
10-31-2017, 01:05 AM | #15 |
10-31-2017, 07:31 AM | #16 |
I use Speed Box- an app for my phone. Got me thru 2 Drag Weeks and a lot of regular driving. It will eat up our battery, though, quick!
10-31-2017, 11:45 AM | #17 |
you can remove the sensor ring from the output shaft and install a plastic gear and clip from early 700r4
11-03-2017, 02:41 PM | #18 |
WAZE app on iPhone
will give you speed and the speed limit also of course good navigation and cop /accident warnings. i use it alot |
11-03-2017, 03:54 PM | #19 |
I use a navman as it's easier for me rather than convert miles to klm. We have speed camera's everywhere over here
11-03-2017, 11:26 PM | #20 |
Yes, I almost forgot about Waze. It's also available on Android.
11-04-2017, 04:29 PM | #21 | |
Sam |
11-05-2017, 04:02 PM | #22 |
I just put a gps on my scooter. Yes i said scooter it dont have any thang.
11-08-2017, 04:27 PM | #23 |
here's one that should fit in your dash.... GPS based 9cm is 3.54 inches so it should fit the hole.
https://www.ebay.com/itm/GPS-MPH-Spe...38.m2548.l4275 |
11-08-2017, 04:28 PM | #24 |
And here's the one my buddy is beta testing for me right now, lol.
https://www.amazon.com/ATACH-DIGITAL.../dp/B01MCXTG12 |
11-12-2017, 02:21 PM | #25 | |
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
