Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-15-2018, 10:55 AM   #1
TxCajun
TxCajun's Avatar
Brazing aluminum zinc die casting ?
The shift lever holes on the "Shift Lever Housing" for my 1966 manual shift column are worn out oblong and cracked, so the shift lever roll pin which should be pressed in is just a wobbly fit.
Can these holes be repaired with aluminum brazing rod and then re-drilled? It appears that the commonly available rods have a melting point of about 720 to 750 degrees, but I have no idea at what temperature the die cast would melt or distort.
I also found ads for a brazing rod product called Muggyweld that has a melting point around 350 degrees, but the cheapest "kit" of rods and flux is around $50.
I was also considering a JB Weld repair of this area, but it seems that there would be a lot of stress at this pivot point. The JB Weld claims a strength of about 4,000 psi whereas the aluminum brazing rod is closer to 20,000 psi.
I haven't had any luck finding a replacement "Shift Lever Housing" locally or online.
TxCajun is offline   Reply With Quote
Old 03-15-2018, 05:13 PM   #2
B. W.
B. W.'s Avatar
Re: Brazing aluminum zinc die casting ?
Post some pics if you can. Also, you might get more hits in the general message board (ask a moderator to move it)
B. W. is offline   Reply With Quote
Old 03-16-2018, 01:42 PM   #3
tinydb84
tinydb84's Avatar
I just spent some time looking it up over on the welding web forum. Seems difficult at best.
Post a picture of what you are working on if you can. I am thinking that having bronze inserts machined and pressed in might be an option.
David
Instagram: myfabguy
Old 03-16-2018, 09:26 PM   #4
PGSigns
PGSigns's Avatar
Have you been through the 60 to 66 parts section? They are out there. You could also become a supporting member and be able to post wanted ads in the parts section. There is not much the folks here don't have.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-17-2018, 04:32 PM   #5
TxCajun
TxCajun's Avatar
Attached are a couple pictures. The pivot holes should be about 7/32" (.218) diameter so that a 7/32" roll/spring pin would be a light press fit. However, the holes are worn in to an oblong about .241" x .281". There are also hairline cracks between the hole and the end of the casting boss so I don't think a bushing would work.
After cleaning up the casting, I found a part number cast on the inside: 3873134. In doing a web search, I found an NOS part for a reasonable price from AutoPartsObsolete, and ordered it so I have a solution.
When I have some time, I may use the old casting to practice aluminum brazing and see if that would actually work for future reference.
Old 03-17-2018, 07:46 PM   #6
dennislbrooks
dennislbrooks's Avatar
Maybe ------ brass/steel sleeve and locktite ----- reaming brass sleeve needs to be carfully done. Or a helicoil/locktite then drill out internal threads to 7/32
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 03-17-2018, 08:04 PM   #7
mongocanfly
Post Whore
mongocanfly's Avatar
i was thinking machine shop/bore/sleeve also.....but I went back and read where he said it was cracked around the hole and collar
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-19-2018, 03:29 PM   #8
sprint_9
sprint_9's Avatar
I JB welded an aluminum sleeve in mine. My holes were oblonged so I drilled them to the OD of the sleeve. Pounded the sleeve in, marked the cut marks, pounded it out and cut it apart and then JB welded the two halves in the collar.
It seemed to work ok but I haven't used it in the truck yet. There are pictures of it in my build thread about 4 or so posts down on the first page.
sprint_9 is offline   Reply With Quote
