10-22-2017, 09:30 PM | #1 |
HELP!!!!Gas Guage driving me crazy
I have a '65 GMC the original guage was complety useless so I bought a gas guage and sending unit from Speedway Motors. Now that I have it installed the needle goes straight to full.As soon as I put power to the guage wham! it hits full with a loud click. I have grounded both the sending unit and the guage. This should be a simple install three wires to hook up.! What is going on?
10-22-2017, 09:52 PM | #2 |
But Found Her 25yrs Later!
Re: HELP!!!!Gas Guage driving me crazy
Is it a replacement fuel gauge for the original fuel gauge in the gauge cluster?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-22-2017, 10:21 PM | #3 | |
Edit: missed you said it was a complete kit Last edited by Mack B; 10-23-2017 at 09:54 PM. Reason: I never learned to read |
10-23-2017, 12:25 AM | #4 |
When hooking up wires, remember the sending unit only varies the amount of ground that the power is seeking. Also, so long as the unit and gauge are properly matched, the pair can run on 30 ohms, 60 ohms, or whatever combo--but they must be matched.
Sam Last edited by luvbowties; 10-23-2017 at 12:30 AM. Reason: add info |
10-23-2017, 09:39 PM | #5 |
The gauge and the sending unit was purchased as a kit, came in the same box so I figure they are matched to each other. I think I will pull the unit out of the tank and check it out, start over and see what happens. Thanks for the responses.
10-23-2017, 11:54 PM | #6 |
I hope you find the answer. My gas gauge does the same thing, just haven't had the time to find out why.
10-24-2017, 09:16 PM | #7 |
Hey Lil Loafer keep me posted on what you find out. I am going to be out of town until next Monday before I will have a chance to look at my truck. Thanks for the interest.
10-24-2017, 11:47 PM | #8 |
60-66 Nut
Sounds like either a ground issue or a bad sender or gauge. I would check your ground to the gas tank first.
10-25-2017, 10:53 AM | #9 | |
10-25-2017, 01:21 PM | #10 |
I think nail pounder may have hit this one on the head.
I don't know if you have an electrical multimeter in your tool box. If you do, disconnect the gauge and measure the resistance from ground to the sender of your tank. If it measures zero ohms (and your tank is not completely full), you have a short in the sender connection and nail pounder's suggestion is probably the issue. You can even remove the sender from the tank, connect the multimeter, and move the float around. You should see the resistance change with the float level. |
10-30-2017, 05:07 AM | #11 | |
HTH, Sam |
Thread Tools | |
Display Modes | |
