2 Steps Forward, 1 Step Back
![]() Join Date: Mar 2016
Brake Light Issue
I have a 1965 C10. I completely rewired the truck using an AAW classic update kit. Up until 2 weeks ago all the lights worked on the truck...no problems. Then, recently, everything works, HL, blinkers, and tail lights except the passenger side brake light. The drivers side works fine...but no brake lights on the passenger side. The tails and blinker work on the PS...just not the brakes.
I checked connections for corrosion, but don't see anything obvious. I do have LED's with an LED flasher and they all work fine. I am stumped where to even look at this point...so I need some help please. |
Re: Brake Light Issue
I believe this indicates a bad turn signal switch. The turn signal switch is responsible for passing the brake signal to the brake lights.
#3 | |
Old member
![]() Quote:
Correct. Try looking at your connector under the dash where it plugs into the harness. I've had a bunch of trouble with those connectors pushing the pins out are hitting a bump and they loose contact with each other. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks, I will take a look at my turn signal harness and see what I find.
#5 | |
