09-04-2016, 11:44 AM | #26 |
Re: Need help with my steering column
When I push on the cup with my fingers it makes a clicking noise like it should but when I put the cap on it will not stay and does not make contact with anything.
09-04-2016, 09:45 PM | #27 | |
The Older Generation
http://67-72chevytrucks.com/vboard/s...d.php?t=437708 http://67-72chevytrucks.com/vboard/s...d.php?t=614258 LockDoc
09-06-2016, 10:34 AM | #28 | |
09-06-2016, 01:02 PM | #29 | |
LockDoc
09-06-2016, 01:03 PM | #30 | |
That said, mine has the black button instead, which is supposed to be for tilt. I was told it's wrong. Can anyone confirm?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-06-2016, 01:41 PM | #31 |
One thing I always forget about when I reinstall my steering wheel and horn button... I have to clock the cup so the cutout lines up to the key on the horn button... My horn button won't stay on if my cup has the notch in any position other than the 12 o'clock position (with the steering wheel straight)
In your picture your wheel is right but the horn cup looks like it needs to turn 120 degrees to put the cup notch at the top then you'd press on the horn button with the notch at the top too.
1969 CST/10 "GreenAndWhite" 1974 Nova (SOLD... End of an Era) 2000 Impala (RIP) 2008 Malibu Brand Loyal... I've never owned a Vehicle not made by Chevrolet. |
09-06-2016, 02:42 PM | #32 |
FWIW - that "pressure plate" you speak of is for the locking columns with the in-column ignition switch, which GM began using in cars starting in 1969, and in trucks starting in 1973.
This paper shows exploded diagrams of a 68 GTO steering column but the parts are similar if not the same other than the steering wheel. http://thefirstgensite.com/library/6.../steering.html
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-06-2016, 07:19 PM | #33 |
Question, dumb perhaps...........Is the button in the canceling cam for the horn?
09-07-2016, 10:09 AM | #34 | |
09-07-2016, 10:11 AM | #35 |
09-07-2016, 10:12 AM | #36 | |
09-07-2016, 02:50 PM | #37 |
These posts are real helpful. I pulled the cap off my 72 to check positioning of the spring loaded pin/button on the canceling cam was located. Like my 71 it's at 10 o-clock. So I put it back together and no horn. It's a new truck to me, and I dumb neglected to see if it worked in the first place. Don't know if cleaning the top of the rim in the steering wheel was it, but now it's working.
Like Doc mentioned, that disk isn't flat. The "dome" side faces rear of the truck. The slot in the retainer faces up to attach the button. If you have the right cup and it's still not working, try backing off the screws a hair, might help. That canceling cam do two different things? One cancel the turn signal and two make contact for horn operation? Guess I'm wondering what the spring loaded pin that contacts the metal disk is used for.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-07-2016 at 02:58 PM. |
09-07-2016, 03:46 PM | #38 |
The cancelling cam also has the horn contact in it, the ground is complete when the horn button is depressed. The turn signal switch has a button in it as well for horn grounding.
09-07-2016, 05:19 PM | #39 |
Just what I was looking for. Thanks a bunch Web.
