Old 01-16-2020, 01:10 AM   #1
fishnixon
fishnixon's Avatar
Swap V8 into 292 6 cyl frame during 4x4 transformation
I am looking for an Accurate measurement based off of a common frame location in order to mount a small block V8 during my K30 transformation. The frame is a C30 that had a 292 6 cylinder. I have made the straight axle swap, but now I need a measurement, as the holes on top of the frame are different when comparing my V8 sb crossmember. I’ve located the holes for the bump stop on the C30 frame that appears to be the same as a K20 frame. The measurement I am looking for is the distance between the bump stop bolt (red arrow) and the front V8 motor crossmember bolt (green arrow). This picture is from a 1968 K20. Currently, this frame is buried in over 2 feet of snow, or I’d measure it myself. Your help is appreciated.
Rob
fishnixon is offline   Reply With Quote
Old 01-16-2020, 11:59 AM   #2
landarts
landarts
Re: Swap V8 into 292 6 cyl frame during 4x4 transformation
I have a K20 at the house with the front clip off, when I get in from work I will get pictures and a measurement for you. Do you have V8 4x4 crossmember for the conversion yet?
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
69 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 01-16-2020, 07:16 PM   #3
landarts
landarts
Here is the measurement from a 72 K20. The tape is on the top of the stop bolt not centered on the bolt.
68 Second Chance
69 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-16-2020, 08:46 PM   #4
fishnixon
fishnixon's Avatar
Thanks for looking into it. I do have a V8 crossmember. It is the one pictured.
How far forward is the center of the front crossmember bolt from the center of the stop bolt? 2 plumb vertical lines must be drawn based on the Centers of the two bolts, then a measurement made of the space between the two vertical lines. Sorry if I didn’t express my question better on my initial post.
Old 01-17-2020, 10:12 AM   #5
landarts
landarts
1/2" center to center of front bolt.
68 Second Chance
69 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 01-17-2020, 02:34 PM   #6
fishnixon
fishnixon's Avatar
Thank you! Your help is very much appreciated! Awesome!
