Old 08-01-2010, 01:51 PM   #1
eyebuzz
Licensed driver
eyebuzz's Avatar
Neutral Safety Switch - Reverse Lights
Hi All,
My reverse lights come on in Neutral. (72 Suburban)
1) Looks like an easy fix - looks like I loosen the bolts to the neutral safety switch at the top of the steering column - just before it enters the engine compartment - and move the assembly around til the back up lights come on - IS THIS CORRECT? By moving the neutral safety switch (there is room to move for the brackets) am I also messing with the starting in P and N ('cause that works fine - just the reverse lights are off).
2) If the above is true - it looks really hard to get a wrench in there to loosen the bolts - anyone done this with common tools - or do I need something special?
Thanks....new here to the board (and to the world of 1972 Suburbans) and really appreciate all that I've learned and read so far.
eyebuzz is offline   Reply With Quote
Old 08-01-2010, 04:36 PM   #2
vectorit
What?
vectorit's Avatar
Re: Neutral Safety Switch - Reverse Lights
You have the right idea, and there are no special tools needed.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-09-2013, 11:14 PM   #3
JointTech
JointTech's Avatar
sorry to bring this back from the dead. Its not a special tool. its a 1/4" socket head. The one on the left side is a real pita to get a tool in to it. I dug out an old barely working really small ratchet and was able to loosen it enough that I could switch to a deep socket 1/4" and loosen it the rest of the way by hand.
I normal size ratchet wont fit and its at a weird enough angle it really sucked.
I got it though
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
backup lights, neutral safety switch
