Old 01-21-2021, 08:10 AM   #1
Worldofhurts
LS Swap Harness AC Wiring pin out Help
I purchased an after market standalone harness and noticed it does not come with the AC request wire. While I have the harness out does anyone know what wire or wires/pin numbers I need to add. My plans are to add a Vintage air AC/Heat set up to my 67' C10. My donor motor is an LQ9 6.0 4l80E out of a 2005 Silverado with a Delphi Green/Blue PCM
Worldofhurts is offline   Reply With Quote
Old 01-21-2021, 10:18 AM   #2
ls1nova71
ls1nova71's Avatar
Re: LS Swap Harness AC Wiring pin out Help
You likely won't be able to do what you are thinking. Starting in 2003 trucks went to a serial data A/C request rather than a 12v one. Just run the VA stand alone and it will be fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-21-2021, 10:27 AM   #3
rodstored-72
chevy truck fan
rodstored-72's Avatar
agree I was looking at trying to use my factory uncut harness from my 2013 and after discussion with V.A. reps (in person) they indicated that the system is designed for their harness only & they do not recommend any variant from their products. in all honesty it actually works out to be a easier install if done as recommended just my 2cts
good luck!!
rodstored-72 is offline   Reply With Quote
