03-26-2002, 07:50 AM | #1 |
67-72 Addict!
How do I brighten a 70 Grille?
Hey guys,
My dad has a nice grille for his truck thats very dull with scratches. Is there a way to brighten it up?. I tried oven cleaner - didn't work. Does anybody know of a product or steps I need to take?. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-26-2002, 08:37 AM | #2 |
I have played with spray on oven cleaner and scotch bright pads.... Try out the technique on your light bezels first...there is a lot of scrubbing to get it shinny. Then you have to put a clear coat on it.
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
03-26-2002, 09:08 AM | #3 |
I've tried this in the last week or so and it is a lot of work. Soak the parts in liquid draino overnight. The anodizing washes off and the you can polish to a high luster. Looks cool though.
1972 K/20 355 c.i.d. sleeper "Circus Wagon" |
03-26-2002, 12:27 PM | #4 |
67-72 Addict!
Did you polish it wish aluminum wheel polish?. Did you use a buffer or by hand?
03-26-2002, 10:13 PM | #5 |
ttt
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Woodstock,IL.northwest of Chicago It's not what you buy, it's what you build!! I did not climb to the top of the food chain, to become a vegetarian. For some pics of my truck. |
03-27-2002, 12:07 AM | #6 |
Eastwood sells a stripper that will remove the coating and then you will have to sand it with a fine grid sandpaper then buff and not with your hand.good luck!
------------------ BIG ORANGE 1971 SUBURBAN 1970/90-Little Buck's Truck (ONE DAY) USED TRUCK PARTS 4 SALE
Things happen for a reason! |
03-27-2002, 09:52 AM | #7 |
I have this polishing compound from "Michiana" polishing in Indiana. Bought it at a swap meet and it works fine by hand but would be quicker with a polishing wheel. I mixed up some draino last night and let it sit too long. Made teh aluminum a little thin. Pay attention on how long you let it sit if you use crystals. I let the premixed liquid plumber sit overnight and it was ok.
03-27-2002, 11:33 AM | #8 |
Oh,you can't buy that new
this is interesting to me as I like to play with parts restorations. I never heard of the draino thing before though . how many gallons does it take to soak one of those huge grille shells in though and did you buy a big tub to put it in? do you think it would work to soak a rag with it and lay it on the grille a section at a time? thanx , DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
03-27-2002, 11:38 AM | #9 |
Shortbox wanna-be.
Have you tried a can of Never Dull? That is what I have used for years. It takes a bit of elbow-grease, but usually turns out ok.
In case you don't know, Never Dull is in a blue can, inside is basically full of cotton that is soaked with some sort of chemical. You just pull out a wad and get scrubbing. It works awesome. Reid ------------------ Sylvan Lake, Alberta, Canada 1970 Chevy C20 Custom Camper #s matching 402BB Turbo 400 trans. Air conditioning, power steering, manual brakes. 73,600 Original Miles!!
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
03-27-2002, 01:56 PM | #10 |
How hard is it to apply the clear coat, what kind of materials are needed?
72' Chevy C-10 rebuilt 350 backed by a TH350 and a 3:73 posi rearend. Located in Mesa, AZ |
03-27-2002, 04:48 PM | #11 |
Dave,
In an answer to your question on part size, I have not done a grill shell yet but don't see why a rag soaked with the solution would not work. For long pieces such as the front fender spears, I put them in a 2" piece of PVC with a cap on the end and fill the pipe with solution. Draino is only $4.50 a can at Wally World and makes quite a few gallons. If your time is worth money, it definitely is faster than sanding. I used to glass bead blast the anodizing off but that lead to a lot of sanding and prep before polishing. Let me know how you like the process.
03-28-2002, 12:16 PM | #12 |
Just an Old Mr Goodwrench
Here's one I "fixed up". It had the usual dents & dings, as well as a nasty series if creases along the top edge. I was able to knock all the dents out and clean up the hammer marks using 220 sandpaper. I then used 320 to get out the 220 scratches, 600 for smoothing and ended up with 1500 grit to get a nice sheen. I finished it off with 0000 steel wool. It's now ready for the black lettering & accent stripes. Took some time, but I'm pleased with the end result! Lee
------------------ 1969 Custom 20 Longhorn 1970 CST 20 Fleetside 1950 Plymouth Special Deluxe 1991 Jaguar Sovereign 1992 Mazda Miata 1969 Triumph Bonneville 1964 Harley Sportster
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
03-28-2002, 01:17 PM | #13 |
67-72 Addict!
Looks great!!!!
